Activity Forums Apple Final Cut Pro Legacy Problem with audio sync transcoding from NTSC to PAL
  • Problem with audio sync transcoding from NTSC to PAL
    Posted by Robert Grove on January 17, 2008 at 12:10 pm
    Hi there!
    I’ve transode NTSC film to PAL [Compressor] and everything is fine
    (NTSC m2v ->DV PAL -> PAL m2v) but when I’m transcoding ac3 file
    with audio track it simply mismatches the video track. I’m a little confused
    because I’ve tried to set either output duration percentage (24@25) and
    by setting output duration by timecode.
    Any help will be appreciated 🙂
    Robert Grove replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
