Activity Forums Blackmagic Design Problem with audio input on multibridge extreme
  • Problem with audio input on multibridge extreme
    Posted by Binjow on August 19, 2006 at 12:42 pm
    Hello,
    I work on winXP pro SP2, and i ve got not access to the decklink audio device for recording analog audio from the multibridge extreme (however it’s working with the play). I go to the sound properties of XP and there is only the output audio for the decklink audio device.
    configuration:
    asus p5ld2 deluxe
    Pentium D 2.8 ghz
    Nvidia geforce 7800 GTX
    binjow
    Binjow replied 20 years, 1 month ago 2 Members · 2 Replies
  • Andrew Mcleod
    August 21, 2006 at 4:30 am
    Multibrridge Extreme requires a token video source to be supplied to capture audio channels accurately. The token video source should match the format of your project.
    Audio channels are embedded with the video stream to remain syncronized.
    The ‘token Video’ can be black video or any source that matches the format.
    If you have any further questions please let me know.
    pcsupport@blackmagic-design.com
    Andrew McLeod
    Blackmagic Design
  • Binjow
    August 21, 2006 at 2:46 pm
    Thanks for the reply, but i want to digitalize audio from a DAT and I want to do it with the XLR analog audio input (video and audio are not embeded and i don’t have any video signal).
    Any solutions?
    Thank you
