Activity Forums VEGAS Pro Problem with audio and transitions
  • Problem with audio and transitions
    Posted by Mike Hite on September 8, 2009 at 1:54 am
    Hello I am having an issue with audio in sony vegas movie studio 9.0
    The problem is any music I use always has some skipping thru out the song. (Sony vegas makes a random skip spot on each song I use) It doesn’t matter what song I use. They all have some form of a skip in them for some reason when I playback in vegas or make a movie.
    They play fine without any skipping outside of vegas.
    Please tell me there is a fix for this!
    I also have an issue with using transitions – Whenever I insert one it causes a major slowdown in preview window and messes with the clip sync time causing random pauses as the clip plays. If I don’t add any transitions at all on my clips they play completely fine.
    I don’t see how adding “one” hard flash transition can cause such a headache.
    Mike Hite replied 17 years ago 1 Member · 1 Reply
  • Mike Hite
    September 10, 2009 at 7:07 pm
    Problem solved – bad import
    It turns out I was importing wrong
    You see I would download a WMV music video off youtube
    Import it and ungroup the video (delete video section)
    drag audio section below my clip
    Some reason this always had a messed up section on every single song when I imported it, but when I watched the video outside of vegas it played completely fine.
    Well after much frustration trying to fix every single video I had made, I decided to try a purchased version so I had to buy the music thru amazon then import the mp3.
    When I did this there was absolutely no error or dropouts at all.
    As for fixing the transitions
    I now always highlight the whole video then hit shift+b
    Then I preview my video.
