Activity Forums Adobe After Effects problem with an expression (that works in other composition)
  • problem with an expression (that works in other composition)
    Posted by Constanti Dinu on September 24, 2015 at 11:43 am
    hello guys,
    i have a problem applying an expression, that otherwise works in a different situation in a different comp (with some variations).
    i have a layer named “Icon options”. in this layer there are some sliders named “1”, another named “2”, “3” and so on
    i have another layer named A,and this layer has a slider named “Opacity number”.
    what i’m trying to achieve is to link the opacity of the layer A to the slider named “1” or “2” or “3” this way:
    – in the layer A i want to assign to the slider named Opacity number the number i want, let s say 2
    – then i want to use the slider named “2” from “Icon options” to modify the opacity for the layer A
    so i’ve tried
    try{
    NAME=Math.floor(effect(“Opacity number”)(“Slider”));
    thisComp.layer(“Icon options”).effect(NAME)(“Slider”);
    } catch (err) {
    x=[0]
    in this point, i’m getting the zero value from the fact that it gets an error. if i remove the catch err, i’m getting this error: Class “Effect” has no proprety or method named “Slider”
    Any ideas?
    Thanks in advance
    Constanti Dinu replied 11 years ago 3 Members · 7 Replies
  • 7 Replies
  • Kalleheikki Kannisto
    September 24, 2015 at 8:20 pm
    I suspect you are getting Effect(“0”) due to the floor expression and you have no slider named “0”.
  • Constanti Dinu
    September 24, 2015 at 8:47 pm
    the thing is i am using the same expression in other comp, with a little variation, where is linked to a color fill, and it works, like this:
    try{
    NUME=thisComp.layer(index).name;
    x = Math.floor(comp(“WORK AREA”).layer(“COLOR US STATES”).effect(NUME)(“Slider”));
    comp(“WORK AREA”).layer(“COLOR SCHEME”).effect(x)(“Color”);
    } catch (err) {
    x=[1,1,1,1]
    September 25, 2015 at 6:36 am
    Perhaps because layer numbering starts with 1.
    I haven’t tried to duplicate your set-up, but try what happens if you change
    NAME=Math.floor(effect("Opacity number")("Slider"));
    to
    NAME=Math.ceil(effect("Opacity number")("Slider"));
  • Constanti Dinu
    September 25, 2015 at 6:42 am
    unfortunately no, the same error
    September 25, 2015 at 8:33 am
    Looks like the expression is not the problem. I recreated your composition based on your description and I get no error.
    9290_iconoptions.aep.zip
  • Walter Soyka
    September 25, 2015 at 10:31 am
    [constanti dinu] “in this point, i’m getting the zero value from the fact that it gets an error. if i remove the catch err, i’m getting this error: Class “Effect” has no proprety or method named “Slider””
    The error is subtle.
    This line:
    returns an integer. Let’s say for the sake of argument, the value is 1.
    Now this line:
    thisComp.layer("Icon options").effect(NAME)("Slider");
    expands to this:
    thisComp.layer("Icon options").effect(1)("Slider");
    This refers to the first effect on the layer, not to an effect named “1”.
    A reference to an effect named “1” uses a string, not an integer, like this:
    thisComp.layer("Icon options").effect("1")("Slider");
    So that first line code needs to store and use the number as a string, not as an integer:
    NAME = "" + Math.floor(effect("Opacity number")("Slider"));
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Constanti Dinu
    September 25, 2015 at 10:44 am
    YOU SIR, ARE A GENIUS!
    i’ve wrapped my head around this for a week. Your expression line worked like a charmThanks a lot, you actually kind of saved my project.
    Also many thanks for everybody else who tried to help me here.
    Cheers!
