Activity Forums Adobe After Effects Problem with AE CS5 and laptop screen resolution during install..
  • Problem with AE CS5 and laptop screen resolution during install..
    Posted by Mohanraj Narayanan on June 15, 2010 at 1:01 pm
    Hello everyone,
    I bought AE and I am very disappointed. When I went to install the application, I got the following errors and it stopped installing.
    Exit Code: 7
    -------------------------------------- Summary --------------------------------------
    - 0 fatal error(s), 54 error(s), 52 warning(s)
    WARNING: Display requirements not met for {DA1B174B-4297-467C-9EF8-0AB8D4D5171E}
    WARNING: Payload cannot be installed due to dependent operation failure
    My max screen resolution is 1366×768 and the requirement is 1280×1024.
    I don’t plan on buying a screen that large. Is there a fix for this? perhaps editing the registry? I won’t mind the small work area. I can manage. does AE CS4 have this resolution requirement? I have an opengl capable graphics card in my laptop so I don’t think that is an issue here. any help would be much appreciated. thanks
    Josef Kyle replied 16 years, 2 months ago 2 Members · 2 Replies
  • Mohanraj Narayanan
    June 15, 2010 at 6:26 pm
    ok I think I was able to bypass the ” Display requirements not met for {DA1B174B-4297-467C-9EF8-0AB8D4D5171E}” error during install. I hooked up an exteral monitor with the required resolution and I did not see that error message again. However, I am still getting the following error messages
    could it be that my graphics card does not support opengl? how can I make sure it supports opengl 2.0?
    My brother has a screen resolution of 1240×780 and yet he was able to install AE CS5 without any errors at all. He has an ATI mobility Raedon Graphics card. whats up with that?
  • Josef Kyle
    June 29, 2010 at 5:56 pm
    Good day to you all!
    Please, I need your advice. I have to buy a laptop able to run Adobe CS5 (the complete suite), but I don’t have too much money.
    Could you, please, tell me if the following computer is what I need? :
    Asus N61JV-JX052V Core i5 430M 2.26GHz 7 Home Premium
    https://www.asus.com/product.aspx?P_ID=RZGwDN2NnWZ7NhbH
    It has Intel i5 430M, 2.26-2.53 GHz, 4 (and up to 8) GB of RAM, 64-bit and Windows 7, Geforce 325M with Open GL 2.1 and Shader Model 4.1 and 1 GB of dedicated memory.
    Two problems though:
    – the resolution is at maximum: 1366×768, while Adobe CS5 requires 1.280 x 900 (1280 x 1024 recommended);
    – the HDD’s speed is 5400 RPM, not 7200 RPM.
    Please, tell me if and how will the two problems interfere with Adobe CS5? The resolution is especially what I fear of. Won’t I be able to install and use Adobe CS5, as I heard?
    Thank you very much!
    Yours,
    Jo.
