Activity › Forums › Adobe After Effects › Problem with adding Knoll Light Factory to solid, the background does not turn transparent as shown in tutorials with older version of KLF
  • Problem with adding Knoll Light Factory to solid, the background does not turn transparent as shown in tutorials with older version of KLF
    Posted by Von Betelgeuse on December 14, 2013 at 5:23 pm
    I’ve got a problem using Knoll Light Factory, when I drag it onto a new solid the background does not turn transparent, it does when adding particular and has been shown to turn transparent in older tutorials.
    I need a Knoll Light to stay in position on a separate transparent layer, how should I go about doing this? :/
    Joseph W. bourke replied 12 years, 9 months ago 3 Members · 3 Replies
  • Mike Zimbard
    December 14, 2013 at 6:40 pm
    This did change in more recent versions of knoll. You now have to activate the unmult setting for the plug-in. Open the “rendering” tab and then click the checkbox next to unmult. You should see the background drop away.
  • Mike Zimbard
  • Joseph W. bourke
    December 14, 2013 at 8:46 pm
    I have always been most pleased with “lighting” effects, including Knoll and Optical Flares, when I create the effect on a black solid, and then composite in Add mode. This adds the values of the brighter pixels to the underlying layers, giving a more convincing, brighter flare.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
