Activity Forums Adobe After Effects Problem while animating vector files in AE
  • Problem while animating vector files in AE
    Posted by Madhanraj Dharmaraj on November 18, 2009 at 8:23 am
    Pls……….. someone help me.
    I created text in AE then i imported vector(.ai) file. I did position animation for vector file with parenting the text. I created camera also. Camera animation is simple zoom in. While
    i do this Im getting frame jerk in vector file and even in text also.
    Things i tried…:
    1. i thought this may be low res so i rendered full resolution even im getting the same problem.
    2. I have applied motion blur to the layer and even gaussian blur filter. it doesn’t work.
    3. Finally i decided to slow down the animation little bit again same problem.
    Camera is not closer to the layers. so what mistake i ve done..
    Pls help me.. im in the last day to deliver the file. client will pissed off. pls pls pls.
    Advance thanks.
    with regards
    Madhanraj.d
    Madhanraj Dharmaraj replied 16 years, 10 months ago 31,160 Members · 2 Replies
  • Madhanraj Dharmaraj
    November 19, 2009 at 5:35 pm
    No not in RAM preview. Open GL enabled.
    Im getting this stutter on the rendered file.
    Format: 1. quicktime movie (Photo jepg)
    2. quicktime movie (Photo 2000)
    3. tga format (24 bit)
    Im working on 2048*868 (2k) dimension compositing.
    pls help me…
    November 21, 2009 at 11:54 am
    Normally i won’t use ‘Open GL’ Mr. Dave. Way to get solution for this issue I tried out. I should thank u for your valuable information. Because i was not tried these combination so i ll get back to u soon.
    One more doubt about hard disk issue which one you specified
    “But your computer’s hard drive probably can’t keep up with the bitrate necessary for such a large animation”.
    If u r connecting to my Color settings of the project and my hard disk then I used for this project is 8 bits per channel. I didn’t get u correctly. thats why im asking you..
    My system config:
    Intel Xeon E5440.
    Quad core processer 2.83 ghz (dual processer)
    Quadro FX 4600/PCI/ SSE2
    8 GB RAM.(Im using windows 32 bit OS so only 3 GB)
    2*500 GB Hard disk.
    AE CS4 will work fine on windows 64 bit version because im having 8 GB RAM but i cant use it ?
    I really very sorry for this passage kind of questions.
    you are my only hope… Pls pls pls forgive me & give some more suggestions to develop myself..
