Activity › Forums › Adobe After Effects › Problem when using Particle world effect with parent camera to null layer?
  • Problem when using Particle world effect with parent camera to null layer?
    Posted by Vuong Nguyen on August 13, 2012 at 6:58 pm
    I started to make a text logo video.
    I created 1 text layer and 1 solid layer for particle world and created 1 3D null layer then parent camera layer with it.
    After that, I modified some value on particle: gravity, x,y,z position to make particle rain.
    The problem is that if I change z position of 3d Null layer, I can see both text layer and Particle layer move following the z axis. But when I set keyframe at 3d null layer’s position, just text layer moved to the z axis, the particle layer doesn’t change any thing.
    Can somebody tell me what is going on? I followed exactly a tutorial from videocopilot.
    Here is af file: https://www.mediafire.com/?4wahxat8k85dbgi
    Felipe Dantas replied 14 years, 1 month ago 3 Members · 3 Replies
  • John Cuevas
    August 14, 2012 at 11:08 pm
    In your file you are only keyframing the text, not the null. I keyframed the null and it worked fine.
    Here’s you file with some changes: 4528_textv2.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Vuong Nguyen
    August 15, 2012 at 12:42 am
    I know that, but can you see the layer Particle that does not move, just layer text. I dont know why when i did it in AE cs5.5 it is ok, but in CS6 i can’t do that.
  • Felipe Dantas
    August 24, 2012 at 8:40 pm
    worked fine for me to (using cs6)
    I key framed the null in the Z axis and.
