Activity › Forums › Avid Media Composer › Problem when exporting???
  • Problem when exporting???
    Posted by Jamie on February 10, 2006 at 5:07 pm
    Hello there
    I’ve got a problem when exporting using Avid Express Pro HD V5sc.15.
    The problem occurs when i try and export as a quicktime movie, using custom setup, with resolution 320 x 240.
    The error dialogue box reads scanning for unrendered AudioSuite plug-ins.
    I have left this running and nothing happens, I must have waited at least 35 mins.
    Can someone please help
    Cheers in advance guys.
    Jamie
    Jon Zanone replied 20 years, 7 months ago 2 Members · 1 Reply
  • Jon Zanone
    February 11, 2006 at 4:43 am
    First, start Audiosuite (tools>audiosuite) BEFORE you export and see if that helps.
    Second, Avid is HORRIBLE at exporting anything other than QT (or reference) same as source (IMO).
    Export full size QT reference, and use Sorenson to compress to a smaller size. The time it takes for the Avid to chunk out your small QT is about the same it will take to get a similiar product out of Sorenson (or Cleaner, or ProCoder, etc.)
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
