Activity › Forums › VEGAS Pro › Problem using Vegas 6 and gearshift…….
  • Problem using Vegas 6 and gearshift…….
    Posted by Simon Wimpenny on June 18, 2006 at 8:15 pm
    Im trying to make a proxy dv video stream with gearshift in Vegas 6, ive loaded the 1 hour M2t clip onto the timeline, the size of the M2t is 11.6GB, i select PAL DV for the converted file, then click on “Entire timeline” within gearshift and click save it to a spare hard drive however the outputted file is coming out at over 300GB!!!
    Is this the correct size or have i got some settings wrong somewhere ?
    i knew it was going to be big but an 11gb file into a 300gb one???
    any help appreciated
    Si
    Peter Wright replied 20 years, 3 months ago 2 Members · 1 Reply
  • Peter Wright
    June 19, 2006 at 1:02 am
    Sounds like you’ve also got it set to make a Cineform Intermediate – make sure that “None” is selected in Gearshift’s HD panel on the right.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
