Activity › Forums › Apple Final Cut Pro › Problem – Second display with OWC Thunderbolt 2 Dock via HDMI
Posted by Tangier Clarke on April 7, 2016 at 7:52 pmHey folks I called OWC which is typically helpful in technical problems, but they had no solution for this.I have a second monitor connected to a 5K iMac via HDMI in built into the OWC thunderbolt 2 dock.
Even though the second display is working with the OS, FCP X does not allow me to show the events or viewers on the second display.
The other thunderbolt port on the dock is taken up by a hard drive so that’s why I am using the handy HDMI.
Any ideas folks?
Tangier
Nikos Papadopoulos replied 10 years, 4 months ago 4 Members · 13 Replies -
Noah Kadner
April 8, 2016 at 12:06 amGuessing that’s not a config that is supported by X.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops -
Jeremy Garchow
April 8, 2016 at 1:48 amPut the hard drive in the OWC and put the monitor back on TBolt.
What computer are you suing? I have an owc2 but haven’t tried what you’re doing. I can do it tomorrow.
Jeremy Garchow
April 8, 2016 at 9:48 pm[Tangier Clarke] “Any ideas folks?”
Just tried this out and it works for me.
HDMI to DVI adapter to 2nd (well, third now) monitor.
HDMI out of OWC Dock 2.
Tangier Clarke
April 9, 2016 at 6:42 amHmmm. The only difference between you and I is you’re going HDMI out to DVI. I am going HDMI out of the dock to HDMI into my second monitor which has both HDMI and DVI.
I can’t believe that I”d have to get an HDMI to DVI cable for this to work.
Tangier
Jeremy Garchow
April 9, 2016 at 1:55 pm[Tangier Clarke] “can’t believe that I”d have to get an HDMI to DVI cable for this to work.
“Unless FCPX is trying to use your hdmi as video out?
Why not take the hdmi out of your iMac instead of using the dock?
Tangier Clarke
April 9, 2016 at 3:27 pmThere is no HMDI out of the iMac Retina 5K. That’s why I like the dock. It has dedicated HDMI. The thunderbolt ports on the iMac are taken.
Tangier
Jeremy Garchow
April 11, 2016 at 2:52 pm[Tangier Clarke] “There is no HMDI out of the iMac Retina 5K. That’s why I like the dock. It has dedicated HDMI. The thunderbolt ports on the iMac are taken.”
Bummer about no HDMI on the 5k.
I am not sure why this wouldn’t work except that HDMI has certain hardware handshakes that need to happen for copy protection (HDCP). SO, perhaps, HDCP compliance isn’t happening with your monitor, and doesn’t work? What monitor is it?
I just tried HDMI out of the dock to HDMI to a Panasonic plasma monitor, and it works just fine. I select to Show Events on second display and the Events are now on the plasma, and if I open the displays sys pref, I even get overscan correction.
I would imagine there is some sort of conflict somewhere. What is hooked up to your Mac?
It would be helpful to know what is daisy chained to each other, and model numbers.
Jeremy
Tangier Clarke
April 14, 2016 at 4:44 pmThe second monitor is an Acer H236HL BID 23″ WIDE LED IPS MONITOR.
Setup is like this:
iMac 5k Retina
Thunderbolt port 1: G-Speed Studio 16TB RAID
Thunderbolt port 2: OWC Thunderbolt 2 DockThunderbolt 2 Dock
Thunderbolt port 1: To iMack 5K Retina
Thunderbolt 2 dock: portable hard drive
HDMI: Acer H236HL BID 23″ WIDE LED IPS MONITORLike your Panasonic Plasma, I am getting picture on the Acer. I just can’t get FCP X to display to it.
Tangier
Jeremy Garchow
April 14, 2016 at 5:19 pmAre you trying to use it as a computer monitor, or a video monitor?
