Activity › Forums › Apple Final Cut Pro › Problem – Second display with OWC Thunderbolt 2 Dock via HDMI
Nikos Papadopoulos replied 10 years, 4 months ago 4 Members · 13 Replies
Tangier Clarke
April 14, 2016 at 5:38 pmJust a second display to place the event browser on. It sounds like the only way to get this to work is use an HDMI to DVI adapter or use one of the dock’s thunderbolt ports to go to DVI.
Tangier
Jeremy Garchow
April 14, 2016 at 5:49 pmMine worked with HDMI to HDMI as well.
Is your AV Output on?
Nikos Papadopoulos
May 10, 2016 at 12:24 amThere are two things you can try before buying weird hdmi to dvi cables (do those even exist?)
1. In system preferences > display settings > arrangement tab you can set your “main” display by dragging the white bar in the blue squares representing your monitor. First try making your non-hdmi monitor as the main one. Inside fcpx disable a/v output. Try showing events on your hdmi display.
2. If the above doesn’t work try in system preferences to set your hdmi display as your main display. Drag the main fcp window to your non hdmi screen. Try showing events on your hdmi display.
Video, music and photography.
nick314.com
