Activity Forums Adobe After Effects Problem rendering my project
  • Problem rendering my project
    Posted by Fredrik Jr on May 12, 2007 at 2:02 pm
    I’ve just finished a little project in AFX and I want to render it out.
    This is my problem:
    I added my footage to the “Render Queue” and pressed Render. 1 second later I heard the “finish-sound”. That can’t be right. The finished file is 0.99MB (way to small), and I can’t see anything when I’m opening it.
    Do you guys know what I’m doing wrong?
    Core 2 Duo E6600 | Evga nf680i SLI | Corsair Dominator PC2-8500 | XFX 8800GTS 640MB | Western Digital 250GB SE16 | Samsung SH-S183A | MIST 600W | Lian-Li V1000 | Zalman CNPS9700NT
    Fredrik Jr replied 19 years, 4 months ago 2 Members · 2 Replies
  • Bart Straman
    May 12, 2007 at 2:14 pm
    heey, mayby your render settings, format etc. if anny of that kind of things doesn’t work. just trash your AE preferences. i rememberd that same problem as well, after deleting these prefs the problems were over. it was a long time ago, so i can’t remember were that preferences file is in your local temp file from adobe. but i’m cetrain you can find that here on the forum.
  • Fredrik Jr
    May 12, 2007 at 2:38 pm
    I fixed it! Since I use PAL, I had to change the frame rate to 25per/s.
    Thanks.
