Activity Forums Apple Final Cut Pro Legacy Problem rendering music tracks.
  • Problem rendering music tracks.
    Posted by Amy Toby on March 16, 2010 at 5:48 pm
    New problem; when i open up an existing project – FCP stalls for about 10 seconds and then everything in my sequence becomes unrendered (red) and i get a “cant locate media” message. Reconnecting media does nothing. Scratch disks are set correctly.
    if i try to render the clips, the picture clips will render but my song/soundtrack underneath will not. If i pull the song out and move it in the sequence, isolate it away from the other clips, then it does render. But I cannot make it render while it is part of the video – ie. while there are picture clips sitting on top of it.
    I have played with sequence settings recently because i needed to make an NTSC DVD, but i have returned all my settings to normal. (I import HDV 1080i, i’m based in Sydney, AUS) I also use multiple hardrives for different project but always re-set scratch disks.
    Any thoughts? Thanks for your help.
    Mike Raff replied 16 years, 5 months ago 2 Members · 3 Replies
  • Mike Raff
    March 16, 2010 at 8:47 pm
    No answers here, but a few questions:
    All AIFs, no mp3s, as your music clips?
    Have you tried the usual voodoo (i.e. Trash prefs, Repair Permissions) ?
    Maybe somebody will know what’s going on.
    Mike Raff
    Richmond, VA
  • Amy Toby
    March 16, 2010 at 11:48 pm
    Hey Mike,
    Im actually using an MP3, so maybe thats my first problem.
    Beyond that though its as if FCP isnt locating the media at all. I noticed that my drive doesnt appear in my finder – only on the desktop.
    Possible crappy drive issues? Im using a 500GB Verbatim USB2 drive.
    Im starting to think it’s a combination of a) mp3, b) crappy drive c) sequence settings….
    its seems a few people i’ve spoken to have a problem where every time you open a project the files all immediately un-render.
    anyone else got ideas?
    cheers,
    A.
  • Mike Raff
    March 17, 2010 at 12:35 am
    Hi, Amy
    Convert the mp3s in iTunes to aif at 48 khz.
    Also, ditch the USB drive and use a FW drive instead. (USBs are thought not to have a fast enough transfer rate to be reliable in Final Cut.)
    Good luck!
    Mike Raff
    Richmond, VA
