Activity Forums Adobe After Effects Expressions Problem referencing same-named properties
  • Problem referencing same-named properties
    Posted by Charles Brepsant on March 29, 2017 at 2:39 pm
    Hi all,
    I have a problem when referencing a property of an effect – specifically the Motion Blur property of the Saber videocopilot effect.
    I use layer(“LAYER”).effect(“Motion Blur”) as a way to reference the property, but the result does not react to the property.
    I am pretty sure this is happening because the property Motion Blur exists multiple times in the effect, according to the following hierarchies:
    – Distortion/Glow Distortion/Motion Blur
    – Distortion/Core Distortion/Motion Blur
    – Render Settings/Motion Blur/Motion Blur
    But I cannot find a way to reference those different properties.
    Is there a way to specify which property we want to select?
    The same thing is happening when I try to reference the property in a script using the following line:
    mysolid.property(“Effects”).property(“Saber”).property(“Motion Blur”).setValue(1)
    I would be grateful if anyone can help on this.
    Thanks in advance
    Charles
    Charles Brepsant replied 9 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 29, 2017 at 4:10 pm
    I would use the Match name, like this for Glow Distortion / Motion Blur:
    .property(“VIDEOCOPILOT LightSaber-0107”)
    If you don’t have Jeff Almasol’s fabulous rd_GimmePropPath.jsx script, get it.
    Dan
  • Charles Brepsant
    March 31, 2017 at 1:21 pm
    Yay, many thanks for the answer Dan!
    I actually had the script but never knew.
    All the best !
