Activity Forums Apple Final Cut Pro Legacy Problem Printing to Video from FCP to JVC SR-VS30U MiniDV/SVHS Hybrid Deck
  • Problem Printing to Video from FCP to JVC SR-VS30U MiniDV/SVHS Hybrid Deck
    Posted by Incertus on October 4, 2006 at 10:02 pm
    I just can’t figure this out. I have no problem capturing from my JVC SR-VS30U MiniDv/SVHS hybrid deck into FCP 4, but cannot for the life of me get anything to happen when I try to print to video, it just prints black. Clearly there is some compatibility issue I don’t understand. HELP! This is really very debilitating. I’ve tried looking at and adjusting any and all settings on both the Mac and the JVC, but nothing seems to be working.
  • Shane Ross
    October 4, 2006 at 10:40 pm
    Just ot verify, here is my big list of things to check:
    #8 External Monitor Viewing.
    Shane’s Stock Answer #8:
    A simple path is mac > firewire > camera or deck > rca cables > tv
    Then start up your camera and tv, then open fcp.
    Then go View > External video > all frames
    Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Bouncing Account needs new email address
    October 5, 2006 at 3:04 am
    Unfortunately these decks are notorious for not working well with NLE’s like FCP.
    Let us know if you get it to work and what you did to make that happen.
