Problem Particular System Rotation with Textured Poligon
Hello,
i am trying to Rotate a simple Particle System in Textured Poligon mode made with Trapcode Particular. I did this by animating the Y Rotation Axis in the Emitter. When Rotating the system without animating it it shows the effect i am trying to get. But if I keyframe animate the Y Parameter the system is not rotating. Am i missing something here or any idea what might be wrong?
I would be so happy to have an answer to this problem 🙂
