Activity Forums Apple Final Cut Pro Legacy problem outputing sequence to mini dv camera
  • problem outputing sequence to mini dv camera
    Posted by Derek Feeney on June 30, 2008 at 4:54 pm
    When trying to print to tape:
    video and audio are not coming out when recording to minidv camera (i tried 2 cams). on the computer it shows the clip outputing on the screen. and the tape is recording blank.
    When edit to tape I get this error:
    “Incompatible compression settings
    You may have attempted to output a clip with compression settings that do not match the current output settings. Try nesting the clip ina sequence with the correct settings.”
    The original clips are .mpg files, FCP is the basic DV NTSC settings, camera is connected via firewire.
    Any ideas?
    Thanks in advance
    Derek
    Shane Ross replied 18 years, 2 months ago 2 Members · 1 Reply
