Activity › Forums › Apple Final Cut Pro Legacy › problem opening .mov file in FCP
  • problem opening .mov file in FCP
    Posted by Jim Mageras on December 12, 2008 at 2:46 am
    Hi everybody! I’m new to the forum and new to FCP.
    I’ve been given some quicktime files that I cannot open in
    FCP 6.0.1
    Here is the QT file data as per Finder:
    -640×480
    -Integer (Big Endian), DV/DVCPRO-NTSC
    -Bit Rate: 30,302
    If I try to open them in FCP I get the following msg: “Unsupported Frame rate, FCP does not support this frame rate or the way it is represented.”
    If I try to drag it into the browser or import I get: “File Error: Unknown File.”
    The bit rate is suspect, but what I’m curious about is that on my G4, I could import the files into imovie (QT Pro) w/o a problem.
    Thanks in advance, Jim
    Paul Campbell replied 17 years, 9 months ago 4 Members · 5 Replies
  • John Pale
    December 12, 2008 at 5:37 am
    open in Quicktime Player. Check its properties. What is its frame rate?
  • Jim Mageras
    December 12, 2008 at 1:55 pm
    29.96!
    What do you think?
  • Jim Mageras
    December 12, 2008 at 1:59 pm
    Sorry, when “playing” QT reports the frame rate as 30fps
  • Shane Ross
    December 12, 2008 at 3:01 pm
    Use Cinema Tools to CONFORM the file to 29.97.
    Shane
  • Paul Campbell
    December 12, 2008 at 8:20 pm
    Shane, would Cinema Tools be a good way to convert 23.98 progressive to 29.97 NTSC? Just curious…
