Activity › Forums › Apple Final Cut Pro Legacy › problem on capture
  • problem on capture
    Posted by Todd Vanslyck on September 1, 2005 at 2:11 pm
    I’m trying to capture some footage that has timecode breakups and image breakups as well. During capture when it hits a p
    articularly bad point, fcp says
    “Capture encontered a problem reading the data on your source tape. This could be due to a problem with the tape…”
    I’ve gone into my settings and told it to ignore until after capture any time code breaks. It is a mini-dv tape being captured from an xl-2s via firewire. How can I bypass this?
    tVs
    Dave Spofford replied 21 years, 1 month ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    September 1, 2005 at 2:17 pm
    The preferred workaround (and its a common problem) is to make an entire copy of the problematic master tape to a new DV tape via FireWire.
    You can use ANY kind of DV camcorders (home-video is fine) or DV decks for making the copy.
    The quality will not suffer and there will be no generation loss.
    You will then have a new tape to capture from with continuous Timecode and the tear-ups will most-likely not be a problem.
  • Todd Vanslyck
    September 1, 2005 at 2:25 pm
    yeah, i thought about that, but i was trying to solve the prob. w/o having to go through all that. Oh, well. Away I go. Thanks
    tvs
  • Dave Spofford
    September 1, 2005 at 4:10 pm
    Have you tried changing your device control to “non controlable device” The is works from me when timecode issues come up.
    –Dave Spofford–
    KVLY TV
