Activity › Forums › Apple Final Cut Pro Legacy › Problem : No external video since Prokit 7
  • Problem : No external video since Prokit 7
    Posted by John Weeks on May 23, 2011 at 9:42 am
    Hi folks
    Need some help with an annoying problem that’s occurred on two of our edit suites since running the Prokit 7 update. Neither are showing ‘live’ footage on the external monitors connected to them.
    They will display a ‘Show Current Frame’ absolutely fine. But when you try playback, nothing. And by nothing I mean no update on the screen, it continues to show the last thing on screen, be it black or the last Show Current Image you brought up. Digital Cinema Desktop Preview DOES work but the external cards don’t.
    The two Mac Pro’s are completely different specs (I’ll include below) with different external video cards (one has a Matrox MXO2, the other a Blackmagic Intensity). I’ve tried a variety of footage and different output specs (dimensions, frame rate, fields) with the same result: no live playback, show current frame works fine. The only thing that’s the same is that they’ve both had Prokit 7 installed on them.
    Has anyone else had this issue or suggest a solution / workaround? This isn’t crippling right now but I’m going to need it fixed in the very near future.
    John
    Suite 1 – ‘Barbarella’
    Model Identifier: MacPro5,1
    Processor Name: 6-Core Intel Xeon
    Processor Speed: 2.66 GHz
    Number Of Processors: 2
    Memory: 16 GB
    Mac OS X 10.6.7
    FCP 7.0.3
    Matrox MX02 – firmware 31.1, software 2.2.1.0042
    Suite 2 – ‘Harvey’
    Model Name: Mac Pro
    Model Identifier: MacPro1,1
    Processor Name: Dual-Core Intel Xeon
    Memory: 16 GB
    Mac OS X 10.6.7
    FCP 7.0.3
    Blackmagic Intensity – 3.9.4
    David Roth weiss replied 15 years, 4 months ago 3 Members · 3 Replies
  • John Weeks
    May 23, 2011 at 10:07 am
    Little update: After Effects is displaying video to the external card fine, as is the Matrox playback app so the problem is definitely in FCP. Have tried trashing FCP prefs to no effect.
  • John Pale
    May 23, 2011 at 1:33 pm
    Reinstall your card drivers.
  • David Roth weiss
    May 23, 2011 at 1:58 pm
    [John Pale] “Reinstall your card drivers.”
    Actually, uninstall then reinstall. AJA, Matrox, and BM all require that you do both, and yes, after updates such as ProKit, it’s very common that I/O drivers need to be reinstalled.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
