Activity › Forums › Adobe After Effects › Problem Moving Object
  • Problem Moving Object
    Posted by Bobby Dorrance on November 9, 2010 at 4:30 am
    Hello,
    I’ve recently had this issue where I cannot move a object with the cc sphere plugin attached to it. I also am unable to zoom with a camera on the object. When I try to move the sphere, it only moves the wireframes around it. I did a screen capture of me going through the process. Here is the link for that https://www.youtube.com/watch?v=JFt3I8lRXPI. Thanks to all responses.
    Bobby D
    Adriano Moraes replied 15 years, 10 months ago 3 Members · 3 Replies
  • Simon Bonner
    November 9, 2010 at 10:42 am
    I don’t have a copy of AE on this machine, but am I right in thinking you need to set up CC Sphere to use the composition camera?
    Simon Bonner
    youtube.com/simonsaysfx
  • Adriano Moraes
    November 9, 2010 at 1:39 pm
    I made a simple test here and the same thing occourred.
    But only when I applyed the CC sphere to a Shape Layer.
    When I apply it to a Solid or to an Image everything works fine.
    It must have something to do with shape layers. I don´t know but maybe the fact that it is made out of stroke and fill and is not actualy a solid coordinate based thing. But now I guess I´m triping.
    Let´s leave the explanation to Todd.
    Try using a solid. It will work.
    ninguem
    ////https://cargocollective.com/ninguem/
  • Adriano Moraes
    November 9, 2010 at 1:55 pm
    And by the way thanks!
    I´ve never thought of applying cc sphere to a shape layer (thought it would be the same as applying it to a solid)
    Now I´m playing around and the possibilities are awesome!
    Cheers!
    ninguem
