Activity Forums VEGAS Pro Problem loading project in SV pro 9
  • Problem loading project in SV pro 9
    Posted by Seranya Myor on January 18, 2011 at 8:35 am
    Whenever I try to open this project it stops loading at 23% and won’t go further. I tried restarting the system, it didn’t solve anything. I opened other projects and they load normally. It happened right after vegas closed itself due to an error while I was rendering it. But it’s got nothing to due with that, since it’s not the first time it happens to me. The other time, I closed a project normally, and a few minutes later I wanted to open it again but it wouldn’t load completely. Yet in no more than 10 minutes of opening and closing projects it finally loaded. But this one won’t load and it’s already been a day. What could be the problem?
    Seranya Myor replied 15 years, 8 months ago 2 Members · 10 Replies
  • 10 Replies
  • John Rofrano
    January 18, 2011 at 1:13 pm
    It could be a bad file. One thing to try is to move the video files to another folder and open the project and tell it to ignore missing media and see if it loads. If it does, then one-by-one add the files back into the original folder and open the project again ignoring missing media. When it freezes, the last file you moved is the problem.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Seranya Myor
    January 18, 2011 at 2:37 pm
    I will try that the next time it happens. Though a minute after I posted this, the project opened normally. If it was a bad file, could it still have loaded properly after all?
  • John Rofrano
    January 18, 2011 at 3:34 pm
    [Seranya Myor] “If it was a bad file, could it still have loaded properly after all?”
    Not likely. I was thinking it was a corrupted file which would always cause the failure. Glad to see it finally opened.
    ~jr
  • Seranya Myor
    January 22, 2011 at 10:18 pm
    I’m still having problems with opening projects. It’s happening more and more often now. I tried moving the files from the project but it still didn’t work. Vegas just stops responding. If it’s not a bad file what could it be?
  • John Rofrano
    January 23, 2011 at 2:22 pm
    [Seranya Myor] ” If it’s not a bad file what could it be?”
    It could be a video format that Vegas doesn’t like. What format are these videos?
    ~jr
  • Seranya Myor
    January 23, 2011 at 3:46 pm
    avi. I used to have trouble with the file format before so I asked here about it and you or someone else told me about avidemux and how I should convert the files to a specific type of avi for them to work in vegas. I’ve been using the same format since and haven’t had problems until recently.
  • John Rofrano
    January 23, 2011 at 5:22 pm
    [Seranya Myor] “avi. I used to have trouble with the file format before so I asked here about it and you or someone else told me about avidemux and how I should convert the files to a specific type of avi for them to work in vegas.”
    That was probably me and I would have told you to convert them to M-JPEG with PCM audio.
    [Seranya Myor] “I’ve been using the same format since and haven’t had problems until recently.”
    So what changed on your computer? (because something did) There must be something you changed about your computer, new software, Microsoft updates, something had to change if they use to work and now they don’t.
    ~jr
  • Seranya Myor
    January 23, 2011 at 5:34 pm
    I don’t know. I don’t remember making any important changes on it lately except for installing newbluefx for vegas and adding 2 GB ram (which are of no help sadly). Those were supposed to improve vegas… it all turned out the opposite of what I needed.
  • John Rofrano
    January 24, 2011 at 1:17 am
    I wonder if Vegas is hanging in memory even though you closed it and it’s keeping another instance from loading. I would try rebooting your computer and then see if you can load the project.
    ~jr
  • Seranya Myor
    January 24, 2011 at 9:51 am
    I did. It was the first thing I tried but it didn’t work.
