Activity Forums Adobe Premiere Pro Problem importing mpeg-2 videos onto adobe premiere cs6
  • Problem importing mpeg-2 videos onto adobe premiere cs6
    Posted by Prashant Satyanarayan on January 29, 2014 at 6:25 am
    hi,
    i am a newbie. i am trying to import mpeg 2 videos onto adobe premiere cs6. however i find that the audio is missing and when i hit the space bar the video remains still, there is no playback. it is more or less like a still image. anyways here is some info about the file. some help would really be appreciated by me. thanks
    General
    CompleteName : D:\work\28-01-2014\SG Content\Raw Videos(Chroma)\SOC_THE_SM_1113_VDO_16_01.MPG
    Format : MPEG-PS
    FileSize/String : 1.97 GiB
    Duration/String : 29mn 27s
    OverallBitRate_Mode/String : Variable
    OverallBitRate/String : 9 594 Kbps
    Video
    ID/String : 224 (0xE0)
    Format : MPEG Video
    Format_Version : Version 2
    Format_Profile : Main@Main
    Format_Settings_BVOP/String : Yes
    Format_Settings_Matrix/String : Custom
    Format_Settings_GOP : M=3, N=12
    BitRate/String : 9 100 Kbps
    Width/String : 720 pixels
    Height/String : 576 pixels
    DisplayAspectRatio/String : 16:9
    FrameRate/String : 25.000 fps
    Standard : PAL
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bits
    ScanType/String : Interlaced
    ScanOrder/String : Top Field First
    Compression_Mode/String : Lossy
    Bits-(Pixel*Frame) : 0.878
    TimeCode_FirstFrame : 00:00:00:00
    TimeCode_Source : Group of pictures header
    StreamSize/String : 1.88 GiB (95%)
    Audio
    ID/String : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Format_Settings_ModeExtension : CM (complete main)
    Format_Settings_Endianness : Big
    MuxingMode : DVD-Video
    BitRate_Mode/String : Constant
    BitRate/String : 256 Kbps
    Channel(s)/String : 2 channels
    ChannelPositions : Front: L R
    SamplingRate/String : 48.0 KHz
    BitDepth/String : 16 bits
    Video_Delay/String : -80ms
    StreamSize/String : 53.9 MiB (3%)
    Pi Yojo replied 12 years, 7 months ago 2 Members · 1 Reply
  • Pi Yojo
    February 11, 2014 at 4:14 pm
    Hi I’m having the same problem playing Mpeg-2 in Premiere Cs-6. No sound. Pressing play only shows a ‘still image’.
