Activity Forums Avid Media Composer Problem importing BWAV into Avid Xpress
  • Problem importing BWAV into Avid Xpress
    Posted by Matt Nasatir on March 13, 2007 at 6:52 am
    We’re converting stereo BWAV files (48kHz, 24-bit) into mono files using Soundgrinder, then trying to import them into Avid Xpress. But when we do, most of them — 2 out of 3 of them — lose their original timecode (and start from 00:00:00:00). When importing these 2 files, Xpress says “converting from QT media”; when converting the one that works, it says “converting WAV media to WAV media”. When importing into FCP, all the files keep their original timecode.
    What’s going on?
    Matt Nasatir replied 19 years, 5 months ago 2 Members · 2 Replies
  • Michael Phillips
    March 13, 2007 at 7:56 am
    THis was an issue in the 5.5 era, what vefsion are you running?
    anything 24fps
  • Matt Nasatir
    March 13, 2007 at 2:35 pm
    we’re running 5.6. i found a post somewhere else that mentioned the same problem with 24-bit files, as with ours. is it possible converting to 16-bit files could solve this problem? i can’t test till later.
