Problem Importing AI Sequence for Cartoonization
I’ve been starting to use Aharon Rabinowitz’s cartoonization process. It works very well! 🙂
Last night I made a cartoon, and then decided that the “cartoon lines” AI files were too dark. I got into Illustrator, changed the lines preset, generated a new sequence of .ai files, and attempted to pull them into AE.
Instead of 5 seconds worthof frames, I only got 1 frame imported. I tried this again and got the same result. I then tried to pull a subset of the first set of line AI files into AE, and it worked fine.
Any idea of what’s going on here?
Thanks much,
Steve
