Activity Forums Apple Final Cut Pro Legacy Problem importing a still into FCP
  • Problem importing a still into FCP
    Posted by Balazs on October 31, 2006 at 12:16 pm
    Hi there,
    thank you all for taking the time to try and help. I have a 25 fps PAL sequence in FCP, and when I import a 720×576 PSD or TIFF file, it is given a vid rate of 29.97 fps (NTSC). I cannot alter this, and so I cannot drop the image into my sequence. How do I modify the still so that I can drop it into my sequence?
    Any comments, help, etc.. is greatly appreciated,
    B
    Jerry Hofmann replied 19 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    October 31, 2006 at 1:52 pm
    I just placed a still reporting 29.97 into a PAL sequence without a hitch… what happens when you do this that stops you from going ahead?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
