Activity Forums Adobe After Effects PROBLEM HELP!
  • PROBLEM HELP!
    Posted by Francois on April 26, 2005 at 6:41 pm
    Hi everyone. I work with AE 6.5 PRO. Everything works fine exept when I render. The RAM line reaches 100% and then the render fails. If I dont clear all the memory, the next render will start at +-98% and then crash again. It never happend before. Is the something corrupted? Is anyone has that troubble before?
    Frank
    Eric Steinberg replied 21 years, 4 months ago 2 Members · 1 Reply
  • Eric Steinberg
    April 26, 2005 at 9:10 pm
    You can purge memory during render by setting the “secret” setting in preferences. Hold the shift key down when accesing preferences, wait till pref dialog appears before letting go of the shift key. Then set to purge every 5 frames or so, maybe less if it still crashes.
    Kind regards,
    Eric
