Activity Forums Maxon Cinema 4D problem getting reflections to render
  • Adam Trachtenberg
    June 20, 2014 at 2:45 pm
    The problem is that there’s nothing in your scene to be reflected. Create a sky object and put some kind of texture on it (preferably HDRI) so there’s something for the reflections to pick up.
  • Simon Huang
    June 25, 2014 at 1:06 pm
    Yeah, i also encountered the same problem. Upon researching it, i discovered that if the surface is not reflective, there is something wrong with the polygon.. Although i have a model and have turned reflection to full blast, it is not even reflecting.. Hope someone knows the answer to this as well XD
