Activity › Forums › Adobe Premiere Pro › problem exporting to tape in premier pro CS3
  • problem exporting to tape in premier pro CS3
    Posted by Jeremy Hettman on September 16, 2008 at 7:23 pm
    I am working on a project which the length is about 65 minutes, i’m trying to export to a 80 minute mini dv tape through firewire in premier pro cs3. I keep getting to about 56 minutes and my tape runs out. Is the time line not giving me an accurate time amount through the sequence? I figure 65 minutes worth of footage should fit on a 80 minute tape right? i’m not sure what i’m doing wrong and i NEED HELP ASAP
    Harm Millaard replied 18 years ago 2 Members · 5 Replies
  • Harm Millaard
    September 16, 2008 at 8:18 pm
    If the tape runs out, the problem most likely is the tape. Are you sure it is 80 minutes?
    Harm Millaard
  • Jeremy Hettman
    September 16, 2008 at 8:22 pm
    that’s what i thought. I’ve tried two different brands that are 80 and 83 minutes and it’s still stopping at 56minutes. i know right, i can’t figure it out
  • Harm Millaard
    September 16, 2008 at 9:32 pm
    You are not using DVCAM mode on those tapes, are you? That could explain the 56 minute limit on an 83 minute DV tape.
    Harm Millaard
  • Jeremy Hettman
    September 17, 2008 at 1:16 pm
    i’m dumping them to a Sony DVCAM/mini DV deck. when you say, DVCAM mode what do you mean? there is a light on the deck that says DVCAM and it is lit when it’s recording yes. ????
  • Harm Millaard
    September 17, 2008 at 1:41 pm
    DVCAM runs at 150% speed of DV, so tapes appear shorter by 50%. Set the deck to DV mode.
    Harm Millaard
