Activity Forums Adobe Premiere Pro Problem Exporting to Encore
  • Problem Exporting to Encore
    Posted by Alex Hawkins on October 25, 2007 at 2:33 am
    Hi there, does anyone know what an “empty project” error is when exporting from PProCS3 to Encore?
    I get this every time and cannot make a DVD directly from the PPro timeline as a consequence.
    Thanks for any light,
    Alex Hawkins
    Canberra, Australia
    Alex Hawkins replied 18 years, 10 months ago 3 Members · 5 Replies
  • Scot Sheely
    October 26, 2007 at 11:34 pm
    Alex,
    How are you Exporting to Encore? Are you rendering an .AVI, an .m2v, or using Project Link?
    Are you using all of the CS3 suite (Encore as well as PPRO)? I know that sounds like it should be assumed so, but in previous support sessions I have had other people throw me for a loop when they told me that they were using older, previous versions of Encore with the newer versions of PPRO. This workflow could affect that as well.
    Are you getting a specific error message with a set of numbers, or only the message as you stated, verbatim?
    Also, knowing a bit about your hardware configuration might help identify this issue as well. Are you a Windows or Mac person?
    Last, but not least, is this the only time you have received this message, while working on this current project? If so, does creating a “Copy” of the current project (go to File menu, choose “Create Copy Of Currrent Project”) help resolve this issue when you open the copy of the project?
    You might possibly have a corrupt project, which although rare, is certainly frustrating, but there are work-arounds in many cases.
    Please post some additional info as I requested and let’s see if we can tackle this issue together.
    Scot Sheely
  • Alex Hawkins
    October 31, 2007 at 12:35 am
    Hi Scott thanks for the reply.
    I am using the File/Export to Encore option, direct burn without menus. The file renders OK but as soon as it opens Encore to start the DVD burn that’s when the message “Empty Project” comes up. That’s all it says.
    It does this with all projects so I don’t believe it’s a corrupt project.
    I am using CS3 Production Premium with Matrox Axio SD. Dual Opteron HPXW9300 workstation.
    Cheers,
    Alex Hawkins
    Canberra, Australia
  • Joe Trepanier
    November 13, 2007 at 1:59 pm
    Are you trying to do this process from within a Matrox project?
    If yes, try creating a new project in an non Matrox editing mode and import your project in to that new project then try again.
    cheers,
    Joe
  • Joe Trepanier
    November 13, 2007 at 2:00 pm
    cheers,
    Joe
  • Alex Hawkins
    November 16, 2007 at 2:42 am
    Thanks Joe, yes I am.
    I finally figured out that CS3 doesn’t like any of the old Matrox Media Encoder presets I made with CS2. Once I re-configured new presets in CS3 and used them instead everything worked fine.
    Thanks for your response.
    Cheers,
    Alex Hawkins
    Canberra, Australia
