Activity › Forums › Media 100 › Problem Exporting Out Of Media 100SW
  • Alex Bond
    January 10, 2006 at 4:25 pm
    Are you sure you can do this at all? I found this on the m100 site when I was looking into SW…
    Media 100 sw will be able to open any program created on Media 100i and continue editing.
    Your Media 100i system will not be able to play a program created on Media 100 sw, but the QuickTime media exported from Media 100 sw will be able to be imported and played out to tape on Media 100i. If you capture your material with timecode then you will also be able to output an EDL from Media 100 sw to be used in a wide range of online conform workflows. All existing import and export workflows, including sending to third party compressors for MPEG2 for DVD or MPEG4 for web, will continue to work as they do with the current shipping Media 100 products.
  • Andy Stinton
    January 10, 2006 at 8:37 pm
