Problem Exporting Movie from Premiere Pro CS4
Hello,
I’m writing from Athens – Greece.
I’m facing a problem exporting my movie from Premiere Pro CS4.Here how the problem goes…
In Greece we have PAL system with 25 fps.
I have a Canon HD camcorder and I shot a movie in 1440×1080 25fps (1,333 pix.rate).
I’ve created a sequence in Premiere Pro CS4 in 1440×1080 25fps anamorphic High Quality preset. To this sequence I added some titles, music, graphics and photos. I wanted to export my movie in a format with high quality (HD if possible) in order to play it to my DVD Home Cinema system, through Adobe Media Encoder.
Although I matched the inserted footage settings with the sequence settings, I’m getting the “red bar” on the timeline sequence panel.
I tried to export it in H.264 format with the following specifications:
PAL, 1440x1080i 25fps High Quality, VBR2 pass, Widescreen 16:9 (1,333 ratio), MP4 MultiplexingThe result was a frame by frame movement with a little blur.
Then I tried to export it in H.264 Blu Ray format with the following specifications:
PAL, 1440×1080 25fps High Quality, VBR2 pass, Widescreen 16:9 (1,333 ratio), TS MultiplexingThe result was the same. A frame by frame movement with a little blur.
I also tried QuickTime with JPEG format and one more time as MPEG-2 Blu-Ray with PAL, 1440×1080 25fps High Quality, VBR2 pass, Widescreen 16:9 (1,333 ratio), TS Multiplexing. The result was not a satisfying one. Again with a frame by frame movement with a little blur.
When I export a partial footage directly from the “Project” panel in H.264, the result is perfect. But it’s not my sequence…
I’m afraid that I’m doing something wrong with the settings and I’ll never get the result I want…
Is there anyone or any way you can help me?
