Activity › Forums › Adobe After Effects › Problem exporting FLV
  • Problem exporting FLV
    Posted by Pacowaco on May 26, 2007 at 3:23 pm
    Hello everyone,
    When I finished my project I tried to export it as a FLV. But somehow I cant export my projects as a FLV anymore. I see only 2 export options: Quicktime and SWF.
    Any suggestions?
    Brendan Coots replied 19 years, 4 months ago 2 Members · 1 Reply
  • Brendan Coots
    June 4, 2007 at 2:50 pm
    Render out of After Effects to Quicktime with Animation codec (or uncompressed AVI), then use the Flash video encoder to convert your render to flash video. If you do not have the Flash Encoder, which comes with Flash, you can use the free and very effective Riva Encoder (link at bottom of post). This workflow is preferable simply because After Effects isn’t the best tool for outputting compressed files, they are almost always larger and lower quality than using an uncompressed file in a third party tool made for compression. I’ve seen tests that prove as much.
    Here’s the link for Riva Encoder:
    https://www.rivavx.com/?encoder
