Activity › Forums › Adobe Premiere Pro › Problem deinterlacing and exporting
  • Problem deinterlacing and exporting
    Posted by David Vincent on August 17, 2012 at 12:39 pm
    I’m using CS5.5 and am trying to export a 720×576 interlaced timeline into an avi file, using Magic Bullet Frames to deinterlace it. Only thing is, when I leave the export settings as they are (lower fields first) it comes out interlaced. What settings should I use for MB Frames to take effect then? Should I choose “progressive scan” in the export settings? I tried that and the quality is muddy.
    PS: I mean what’s the purpose of MB Frames if, no matter what, the Premiere export settings only are responsible for the file being interlaced or deinterlaced?
    David Vincent replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
