Activity Forums Adobe After Effects Problem creating scalable line drawing
  • Problem creating scalable line drawing
    Posted by Steve Dann on May 29, 2010 at 1:25 pm
    Hit the buffers on this one. Need to produce a line drawing using paint tool on a solid that I can then zoom in on. There seems to be an issue with the continually rasterise button. I can only scale things with rasterise switched off … no good. Also I had to select every brushstroke to make that happen. Should I have pre-comped? What’s the best way of doing this? I’ve considered making a comp way larger than the DV widescreen size I need so degradation from zooming in doesn’t matter but don’t want long render times. I have to do tis in AE, no time or budget to do it in Illustrator or whatever. Grateful for any ideas.
    Erik Waluska replied 16 years, 4 months ago 2 Members · 1 Reply
