Activity › Forums › Adobe Premiere Pro › Problem converting HDV to DV
  • Problem converting HDV to DV
    Posted by James Mclean on February 19, 2011 at 12:55 am
    We shot 5 hours of HDV footage.
    Our camera wasn’t set on “Down-Convert” (we tried to set it but it wouldn’t let us) so we couldn’t capture it onto our normal editing program (old version of Adobe Premiere Pro, number 7 I think, which only plays DV footage).
    So we captured it on Final Cut Pro but that captured it in HDV. So now we need to convert it to DV.
    James Mclean replied 15 years, 7 months ago 3 Members · 5 Replies
  • Alex Gerulaitis
    February 19, 2011 at 1:13 am
    [James McLean] “We shot 5 hours of HDV footage.
    So we captured it on Final Cut Pro but that captured it in HDV. So now we need to convert it to DV.”
    I think that in-camera down-conversion only works on analog and uncompressed digital (SDI) output but not DV/HDV.
    Two options then:
    • re-render your footage in FCP or other software (Squeeze, AME, etc.);
    • re-capture using a different mechanism: set the camera to down-conversion; connect its S-Video port to a GV ADVC-110 or similar analog-to-DV converter; capture the output of the converter via FireWire into FCP or Pr.
    Alex
    DV411
  • Ann Bens
    February 19, 2011 at 1:27 am
    Imo its better and easiest way is to set the hdv camera to downconvert and capture it as DV through firewire on CS5 directly.
  • Ann Bens
    February 19, 2011 at 7:07 pm
    Should say Pro 7. Downconverting is done in the camera so Pro should be able to see the DV stream.
  • Alex Gerulaitis
    February 22, 2011 at 1:50 am
    [Ann Bens] “Imo its better and easiest way is to set the hdv camera to downconvert and capture it as DV through firewire on CS5 directly.”
    I think you’re right that it’s the easiest, and should be possible – e.g. Sony FX1, Z1 and Z5 all support down-conversion on the fly via FireWire/DV.
    James did say his camera wouldn’t let him; is it possible his camera doesn’t support on the fly down-conversion?
    Alex
    DV411
  • James Mclean
    February 22, 2011 at 2:41 am
    Thanks for all your help, Alex and Ann.
    We’re trying to load the footage again. See how it goes. 🙂
