Activity Forums Maxon Cinema 4D PROBLEM!!!!! Ciname4D renders different in viewport than the actual render
  • PROBLEM!!!!! Ciname4D renders different in viewport than the actual render
    Posted by Rayhan Shahwani on December 12, 2019 at 12:26 am
    Hi folks!
    So, I’m trying to render a simple animation using the “cel renderer” effect. I have my animation in C4D however when I press “render” it renders completely different than that of the “viewport” render.
    What’s the problem here, why can’t I render identical to that of the viewport? Here’s the picture below!
    Link – https://bit.ly/35fy0Pd
    Any help would be appreciated, thanks!
    Steve Bentley replied 6 years, 8 months ago 3 Members · 2 Replies
  • Justin Thomson
    December 12, 2019 at 3:10 pm
    Will need to see the file. might have something to do with the Sub Surface.
    When you get to the top, don’t forget to send the elevator down for the next guy
  • Steve Bentley
    December 13, 2019 at 2:19 am
    Is it just that the subD object is set for a higher poly count in the render vs the viewport?
    Whoops got that backwards. I mean its set for lower in the render. (swap those numbers in the attached image)
