Problem: Capturing HDV footage in FCP5
Hi Everyone!
I am trying to capture using a Sony HDV-FX1 and FCP5, and I am having problems. Does anyone know the Audio/Video Settings I should be using (in FCP5) and wether I need to change the settings on the camera at all?
* The footage has been shot in HDV 1080i (not sure wether to use 50hz or 60hz presets in FCP5, have tried both though and still cant get capturing)
* Current Audio/Video settings (not working) are:
Sequence Preset: HDV 1080i60
Capture Preset: HDV
Device Control Preset: Sony HDV Firewire
Video Playback: None
Audio Playback: DefaultOverall Problem: I cant capture the HDV1080i footage, I also cant see a preview of it in the log and capture viewer slug. When i try to capture with these settings, FCP5 doesnt recieve any video at all. I’ve tried using other settings and I get errors for one reason or another.
I know it is possible for me to downgrade the footage to dv, However I dont want to downgrade my footage as you can understand I want to solve this problem and be able to capture and edit in HDV. Can someone please help with this problem?? If you do have a FX1 and it works can you please let me know your settings!!!
Thanks!!
Matt.
