Activity › Forums › Adobe Premiere Pro › Problem at recording sound directly to Premiere Pro with Zoom H1
  • Problem at recording sound directly to Premiere Pro with Zoom H1
    Posted by Engin Osmanovski on December 29, 2012 at 4:03 pm
    I attached a Zoom H1 to my laptop with a USB cable to use it as an interface (as mentioned in the user manual), and recorded sound directly to my Premiere Pro timeline. Nothing is wrong with my ASIO settings or input levels adjustments but the recorded sound is all distorted. It is too loud. Is there a way to record it properly? What am i doing wrong? Is it impossible to record decent sound directly to our computer with a Zoom H1?
    Angelo Lorenzo replied 13 years, 9 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    December 29, 2012 at 9:10 pm
    I know this happens for Windows, but I’m not sure if this is the same behavior for OSX.
    You have to deal with setting all your gain stages. Gain stages are points in your signal chain where the audio is being processed where gain (volume, basically) can or is adjusted.
    You have:
    1. Device (optional). If you have a Mic, it won’t be adjustable, but if you have say a electric keyboard then it is.
    2. Pre-Amp (optional)
    3. Input board. In this case it is your Zoom acting as an input or interface for your computer.
    4. Windows will have a recording input level, even for ASIO devices. For your situation I have a hunch this is where the problem lies.
    5. Premiere’s record input level. This may or may not be a factor. I think it only uses gain for playback.
    The goal is to have as hot (loud) as the rest of the process chain can handle, as early in the chain as you can. If you amplify later in the processing chain then you’ll usually end up with more noise (a higher noise floor).
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
