Activity › Forums › Adobe Premiere Pro › probleam whit Premiere cs5!!
Posted by Shai Malul on December 26, 2010 at 10:00 ami have a new computer: i7-8gb-ram-xfx hd 5970 and more.
i try to work whit Premiere cs5 but the program stock after every 5-8 min of work.
what sould i do??Brian Louis replied 15 years, 9 months ago 3 Members · 4 Replies -
Andrew Devis
December 26, 2010 at 4:23 pmFirst thing to do is make sure you have downloaded all updates to CS5, your graphics card driver and system. Then restart and go from there.
For more advice it would help to know what you are doing exactly.
Hope this helps
Andrew… because it’s all about stories …
Shai Malul
December 26, 2010 at 7:25 pmhey andrew and thanks for the advice.
well, trying the edit a sequence in the ppro cs5.
and every few min’ the program is stock and NOT RESPOND any more.
the program stock in a random way (after a saveing/after i add a filter or for no reson).
i use some clips of a regular mpeg file and some BORIS video filters.
i think it is connected to something on the program setting.
my graphics is update and i have download cs5 updte from adobe site.
i well setup the update and post.thaks for the help 🙂
Shai Malul
December 27, 2010 at 10:25 ami upadte the program and i still stock after 5-8 min of working
Brian Louis
January 2, 2011 at 11:26 am[shai malul] “trying the edit a sequence in the ppro cs5.
and every few min’ the program is stock and NOT RESPOND any more”
We can assume that you are trying to edit something, but what kind of footage and you should also note more info on your system, like your harddrive setup and how many, etc
