Activity Forums Avid Media Composer proble with MXF file
  • proble with MXF file
    Posted by Alessandro Cerquetti on September 7, 2011 at 10:10 pm
    I’m working in AVID media Composer 5 Apple system, format 720 i.
    I’ve same files in to HD lacie 2 Tera of my Avid project all this edit in one sequence. but now, I can’t more load , they because are MEDIA OFF LINE.
    But this file are inside lacie : Avidmedia Files/1/ but not load, i see they
    Ok, tray from media tool find it, and they exit media file but only with audio file…. no video!!!
    Help me
    Thank you
    Alessandro Cerquetti replied 15 years ago 3 Members · 3 Replies
  • Khoren Mirzakhanian
    September 7, 2011 at 10:35 pm
    Quit Avid, delete media creation files. “msmFMID.pmr” “msmMMOB.mdb”
    They are located in your Avid MediaFiles -> MXF -> 1 -> folder
    Let it scan all media, any “Avid MediaFiles” folders that are available on the system.
    If the clip is still offline, try to relink.
    Hope this helps.
  • Shane Ross
    September 8, 2011 at 5:02 am
    Make sure that you have the “1” folder inside a folder called MXF, that is inside the Avid MediaFiles folder. If you don’t have that exact file structure, Avid won’t see the media.
    Shane
  • Alessandro Cerquetti
    September 8, 2011 at 10:07 am
    OK resolved!!
    My folder was corrupts, I’have copy all MXF files in new folders renemad as “AVIDMEDIA FILE/MXF/1 and delete all old folders.
    This is all.
    Thank you
