Activity Forums Zaxwerks ProAnimator render has horizontal artifacts @ FILM rez
  • ProAnimator render has horizontal artifacts @ FILM rez
    Posted by Richard Brooker on October 24, 2006 at 10:56 pm
    Greetings.
    I am working in ProAnimator 4.0.2 to create silver-ish type with red bevelled edges. I used a default texture (#14 in Object Styles – blue/gray chrome with blue reflective edges – I changed the edges to red). FWIW my Machine is a G5 Powermac Quad running OSX 10.4.8.
    The graphic was approved by the client (whew!) at video res. Now I am trying to rez it up for print use. Rendered at the highest res in ProAnimator “FILM” 4096 pixels wide, I am seeing thin random horizontal line artifacts on the faces of the type and also on the sides.
    I am using the Invigorator renderer. I tried the OpenGL renderer, got cleaner results, except the type was all kind of squeezed into the lower left quadrant.
    I hope I’ve been thorough enough in my desciption of the problem.
    Has anyone seen this before? Any suggestions for getting a clean render at this higher rez?
    Thanks and best wishes,
    Richard Brooker
    Richard Brooker replied 19 years, 10 months ago 3 Members · 5 Replies
  • Matt Rhodes
    October 25, 2006 at 12:22 am
    Hi Richard.
    Is there any chance you could post a screen shot of what you’re seeing.
    Also, is there any way you can send me a version of your project so that I can take a look
    at the artifacts? There may be a rendering bug.
    Thanks a lot.
    Matt Rhodes
    Zaxwerks, Inc.
  • Matt Rhodes
    October 25, 2006 at 12:24 am
    You can send files to: matt@zaxwerks.com
    Matt Rhodes
    Zaxwerks, Inc.
  • Richard Brooker
    October 25, 2006 at 6:41 pm
    Thank you Matt for fixing this for me (offlist)!
    Richard
  • Jon Okerstrom
    October 26, 2006 at 1:35 am
    Hi Richard and Matt..
    Just curious… was it a rendering error, a model problem or something else… reversed normals?
    Jon
  • Richard Brooker
    October 26, 2006 at 2:47 am
    Hello Jon.
    It was something about “rendering optimization code that didn’t look too good at these levels.”
    I should let Matt answer this one, it’s way over my head.
    It got fixed and I’m a happy camper!
    Richard
