Activity Forums Zaxwerks ProAnimator Plug-in In AECS3
  • ProAnimator Plug-in In AECS3
    Posted by Donovan Werts on April 17, 2008 at 1:49 am
    Hi, I’m loving the ProAnimator Plug-in In AECS3. Just have one issue. When I create an object style for text in the full version of ProAnimator, and save it, I can apply it to other text objects with no problem. When I am working in AE CS3 and create a new solid layer, then go to the ProAnimator Plug-in under Effects to create 3d Text, it seems the object styles that I created and saved in the full version aren’t there. They are there when I open up the full version again (not the plug-in).
    Anyone else experience this? Is it normal, and is there a fix? Seems like with the full version or plug in, that the same “library” of object styles would be accessable.
    Thank you, Donovan
    Donovan Werts replied 18 years, 5 months ago 2 Members · 2 Replies
  • Matt Rhodes
    April 17, 2008 at 5:33 pm
    Hi Donovan.
    We just updated PA to v4.5, which moves the Swatches Libraries (and Presets, and Maps) to a common folder, so I’d suggest doing the following:
    1. Go to https://zaxwerks.com/download and download PA v4.5. Install v4.5.
    2. Open the ProAnimator application *first* (do this before opening the AE plug-in version of PA).
    3. Your PA app and plug-in should now share a common set of Swatches.
    The new, shared Swatches are in /Zaxwerks/ProAnimator
    Let us know if you have any questions.
    Matt Rhodes
    Zaxwerks, Inc.
  • Donovan Werts
    April 17, 2008 at 5:54 pm
    Thank you for the info, I’ll give that a try this evening. Donovan
