Activity Forums Zaxwerks ProAnimator-Illustrator Pathfinder Problem
  • ProAnimator-Illustrator Pathfinder Problem
    Posted by Ryan Broom on March 24, 2009 at 5:33 pm
    I traced out a picture of a television in Illustrator and used the the pathfinder tool to subtract the tube section from the main television body. When I import the Illustrator file into ProAnimator the tube section is not cut out. Is there something I’m doing wrong? Thank you for your help.
    Edward Wu replied 17 years, 6 months ago 2 Members · 3 Replies
  • Edward Wu
    March 24, 2009 at 11:33 pm
    Hi Ryan,
    When you use the “Pathfinder > Subtract” tool to cut out a hole in the television, make sure you use the “Expand” command as well.
    Once you use “Expand”, you should be able to see the cut out when you open the Illustrator Object in ProAnimator.
    Best,
    Edward
  • Ryan Broom
    March 25, 2009 at 2:39 pm
    That fixed the problem, thank you for the help.
  • Edward Wu
    March 25, 2009 at 4:25 pm
    Not a problem. Thanks for the update!
