Proanimator general problems
Posted by Don Bitters iii on March 30, 2010 at 11:31 pmI’ll try to give as much detail as I can to prevent confusion.
Proanimator acts incredibly unstable across all of our work computers (MacOS X, dual 3.2 Quad-Core Intel Xeons, 22GB Ram) in AE CS3, causing random corruptions even when active with comps that don’t even contain proanimator layers/effects, it crashes randomly when clicking “cancel” or “ok”, or tweaking any 3d object, and subsequentially corrupts the AE projects in the process.
The list could go on forever, but what I want to know is if there is any wholesale fix for these problems? We have what I believe to be the latest version of the plugin (4.5.1) and the latest updates to both the Mac OS’s and After Effects. Are there other plugins that could be causing conflicts?
As I said, the crashes, errors, and corruptions are so rampant that there’s no way to narrow it down to one problem. Reinstalling the OS, AE, and Proanimator have all yielded the same results, no matter the system. No other plugin we use has these issues, so I can assume there’s no memory or hardware conflicts. I’ve tried both with and without GL high quality settings on and off.
Is the software just that buggy, or am I missing something obvious?
Help! (and Thanks)
Edward Wu replied 16 years, 5 months ago 2 Members · 6 Replies -
Edward Wu
March 31, 2010 at 5:21 pmHi Don,
If you are running into an issue with corruption, try clearing the ProAnimator Preference file. To do this, go into the “Users > Library > Preferences” folder, and delete the “ProAnimator Prefs” file. This should allow you to open projects that have been corrupted.
When you run into a crash in After Effects, it will ask you if you’d like to save the project. However, the crash save file is usually unstable and could cause more crashes. So, it’s usually not a good idea to work from those saved projects.
In terms of crashes and conflicts, here’s what we are aware of. If you have undocked panels within After Effects, this will cause a conflict with the ProAnimator windows. To fix this, dock all your After Effects panels before running ProAnimator. Also, the plug-in Nucleo Pro, and the After Effects Multiprocessing setting have caused conflicts with some of our plug-ins in the past. So, you can try disabling these and see if they help.
I realize that you mentioned you are having crashes randomly. However, if you find that you are having crashes more commonly with something, please save the crash log for that process so we can investigate what you are running into.
Best,
Edward -
Don Bitters iii
March 31, 2010 at 5:24 pmWhere does the crash log save to? Or are you referring to the general AE project .log file?
Edward Wu
March 31, 2010 at 5:38 pmHi Don,
What I am referring to is that when After Effects crashes, you will be able to click on “Report” or “Ignore”. When you click on the “Report” button, you’ll see a log that contains the After Effects crash information. You can copy and paste the information into a text file, and attach that crash log in an e-mail to me.
My e-mail address is ed@zaxwerks.com
Please let me know what procedure you were doing when the crash occurred. Thanks.
Best,
Edward -
Don Bitters iii
April 5, 2010 at 6:37 pmI’ve attached the text from the latest crash report-
Date/Time: 2010-04-05 11:33:45 -0700
OS Version: 10.5.8 (Build 9L31a)
Architecture: i386
Report Version: 4Command: After Effects
Path: /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/After Effects
Version: 8.0.2 (8.0.2)
Parent: launchd [113]PID: 240
Event: hang
Time: 5.03s
Steps: 26Process: After Effects [240]
Path: /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/After EffectsADDRESS BINARY
00001000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/After Effects
00008000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ALOG.dylib
0000c000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AEFX.dylib
00038000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ADM.dylib
00070000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/BEZ.dylib
00082000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/BM.dylib
0008e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/COR.dylib
000d6000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/FILE.dylib
000f3000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/FLO.dylib
0013a000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/FLT.dylib
001c5000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/LIST.dylib
001ce000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/M.dylib
001e7000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/MC.dylib
001f8000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/MSK.dylib
0026f000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/OM.dylib
0028e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/P.dylib
002b7000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/PLUG.dylib
002d7000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/PR.dylib
002e3000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/PREF.dylib
002ed000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/RG.dylib
0030e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/RI.dylib
00314000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/RND.dylib
0031d000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/SLU.dylib
00324000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/STR.dylib
0032b000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/T.dylib
00332000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/VAL.dylib
00339000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/PRM.framework/Versions/A/PRM
00539000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/PIN.dylib
006c5000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/SND.dylib
006e3000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/TDB.dylib
00734000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/U.dylib
0076b000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeSpartacusEve2.framework/Versions/A/AdobeSpartacusEve2
007d8000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeSpartacusKernel.framework/Versions/A/AdobeSpartacusKernel
007f6000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeSpartacusZString.framework/Versions/A/AdobeSpartacusZString
00833000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ASLTests.framework/Versions/A/ASLTests
0088e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/Memory.framework/Versions/A/Memory
00895000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/MemoryShell.framework/Versions/A/MemoryShell
00b44000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AfterFX.framework/Versions/A/AfterFX
01688000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/BEE.dylib
01bc1000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/PF.dylib
01f5e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/TXT.dylib
0251e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
0266a000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
0269b000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
0279d000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/Backend.framework/Versions/A/Backend
04151000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
0437c000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
043b0000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/livelink.framework/Versions/A/livelink
0443d000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/exo.framework/Versions/A/exo
045cb000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/PREM.dylib
045ef000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AudioFilters.framework/Versions/A/AudioFilters
04677000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/MediaLayer.framework/Versions/A/MediaLayer
05001000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/VideoFrame.framework/Versions/A/VideoFrame
0505a000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/FRP.dylib
050be000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/aif.framework/Versions/A/aif
059d9000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/basic_library.framework/Versions/A/basic_library
059fc000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
05ae3000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
05bb5000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeACE.framework/Versions/A/AdobeACE
05cd8000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
062cf000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeARE.framework/Versions/A/AdobeARE
06318000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0633d000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0636b000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0665a000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
069ee000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
06a24000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedExpat
06a60000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
06ac3000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
06c87000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
07280000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
072da000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobePSL.framework/Versions/A/AdobePSL
082a3000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/dvacore.framework/Versions/A/dvacore
0855c000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/dvaeve.framework/Versions/A/dvaeve
08820000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/dvaui.framework/Versions/A/dvaui
08bd8000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
08d4b000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/FileInfo.framework/Versions/A/FileInfo
08e2f000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
08e82000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/adobe_caps.framework/Versions/A/adobe_caps
08ed9000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ImporterQTMutex.framework/Versions/A/ImporterQTMutex
08ede000 /usr/lib/libmx.A.dylib
0ad69000 /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0ad91000 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0afc5000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Matte_Choker.plugin/Contents/MacOS/Matte_Choker
0afe0000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Blur+Sharpen/S_DefocusPrism.plugin/Contents/MacOS/S_DefocusPrism
0afe5000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Stylize/S_EdgeDetect.plugin/Contents/MacOS/S_EdgeDetect
1e3e6000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/DirectionalBlur.plugin/Contents/MacOS/DirectionalBlur
1e3ed000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Set_Channels.plugin/Contents/MacOS/Set_Channels
1e408000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Channel_Blur.plugin/Contents/MacOS/Channel_Blur
1e435000 /System/Library/Contextual Menu Items/BluetoothContextualMenu.plugin/Contents/MacOS/BluetoothContextualMenu
1e500000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Stroke.plugin/Contents/MacOS/Stroke
1e50d000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Distort/S_WarpFishEye.plugin/Contents/MacOS/S_WarpFishEye
1e711000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
1e760000 /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
1e8ca000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Render/S_Grid.plugin/Contents/MacOS/S_Grid
1e8cf000 /System/Library/PrivateFrameworks/URLMount.framework/URLMount
1e92c000 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
1e984000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
1eac1000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Blur+Sharpen/S_GrainRemove.plugin/Contents/MacOS/S_GrainRemove
1eaef000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
1ec00000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
1ef39000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Render/S_GradientMulti.plugin/Contents/MacOS/S_GradientMulti
1ef92000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/adobe_epic.framework/adobe_epic
1efe7000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/adobe_eula.framework/adobe_eula
1f055000 /Library/QuickTime/DVCPROHDVideoOutputCodec.component/Contents/MacOS/DVCPROHDVideoOutputCodec
1f08d000 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
1f11a000 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
1f19f000 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
1f1eb000 /Library/Frameworks/Motion.framework/Versions/A/Motion
1f256000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterAiff.bundle/Contents/MacOS/ImporterAiff
1f364000 /Applications/Adobe After Effects CS3/Plug-ins/Extensions/Mac G5.plugin/Contents/MacOS/g5_opt
1f386000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Linear_Wipe.plugin/Contents/MacOS/Linear_Wipe
1f38b000 /Applications/Adobe After Effects CS3/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
1f3d9000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Render/S_TexturePlasma.plugin/Contents/MacOS/S_TexturePlasma
1f485000 /Applications/Adobe After Effects CS3/Plug-ins/Format/Animated GIF.plugin/Contents/MacOS/agif
1f48e000 /Applications/Adobe After Effects CS3/Plug-ins/Format/Filmstrip.plugin/Contents/MacOS/Film
1f4a2000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
1f509000 /Applications/Adobe After Effects CS3/Plug-ins/Format/PS Layer Export.plugin/Contents/MacOS/PS3Export
1f51e000 /Applications/Adobe After Effects CS3/Plug-ins/Format/PS Layer Import.plugin/Contents/MacOS/PS3Import
1f54a000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
1f551000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
1f558000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
1f560000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
1f567000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
1f90f000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/mcdvd_32.framework/mcdvd_32
1fab5000 /Library/QuickTime/AJACodec.component/Contents/MacOS/AJACodec
1fae4000 /Library/QuickTime/AppleProRes422.component/Contents/MacOS/AppleProRes422
1fb6a000 /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
1ffaa000 /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
20003000 /System/Library/Components/VCH263Codec.component/VCH263Codec
20052000 /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
20113000 /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
2016a000 /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
20189000 /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
201c1000 /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
201df000 /Library/QuickTime/AJAVideoOutputCodec.component/Contents/MacOS/AJAVideoOutputCodec
20222000 /Library/QuickTime/Perian.component/Contents/MacOS/Perian
20827000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterFastMPEG.bundle/Contents/MacOS/ImporterFastMPEG
20852000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
20911000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterFlash.bundle/Contents/MacOS/ImporterFlash
20948000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterMP3.bundle/Contents/MacOS/ImporterMp3
209a0000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
209b1000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterP2.bundle/Contents/MacOS/../Frameworks/libxalanMsg.dylib
209bb000 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
209fc000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/mcmpgvdec.framework/Versions/1.2.16471.0/mcmpgvdec
20b7e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterP2.bundle/Contents/MacOS/ImporterP2
21000000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterP2.bundle/Contents/MacOS/../Frameworks/libxerces-c.26.dylib
21430000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterP2.bundle/Contents/MacOS/../Frameworks/libMOG_Framework_r.2.0.7.92.dylib
2147e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterP2.bundle/Contents/MacOS/../Frameworks/libMXF_SDK_r.4.1.1.223.dylib
218cc000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterP2.bundle/Contents/MacOS/../Frameworks/libMXF_SDK_XML_r.4.1.1.223.dylib
2193c000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterQT.bundle/Contents/MacOS/ImporterQT
21992000 /System/Library/Components/IOQTComponents.component/Contents/MacOS/IOQTComponents
2199b000 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
219e3000 /Library/QuickTime/AppleMPEG2Codec.component/Contents/MacOS/AppleMPEG2Codec
219ee000 /System/Library/Components/PDFImporter.component/Contents/MacOS/PDFImporter
219f6000 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
21c00000 /System/Library/QuickTime/AppleProResDecoder.component/Contents/MacOS/AppleProResDecoder
21c8d000 /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
21dad000 /System/Library/QuickTime/QuickTimeVR.component/Contents/MacOS/QuickTimeVR
21e73000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterWave.bundle/Contents/MacOS/ImporterWave
21e83000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/PlayerMac.bundle/Contents/MacOS/PlayerMac
21f4a000 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
21f56000 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
21fdc000 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
221e4000 /Applications/Adobe After Effects CS3/Plug-ins/DE_BuenaDepthCueMac/Depth Helper.plugin/Contents/MacOS/Depth Helper
221ee000 /Applications/Adobe After Effects CS3/Plug-ins/DE_BuenaDepthCueMac/Falloff Lighting Helper.plugin/Contents/MacOS/Falloff Lighting Helper
221f7000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
22300000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
2237f000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
223bd000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
22412000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
22444000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
22480000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
224ad000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
224ec000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
22519000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
2256c000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
22595000 /Applications/Adobe After Effects CS3/Plug-ins/DE_BuenaDepthCueMac/Fog Helper.plugin/Contents/MacOS/Fog Helper
2259f000 /Applications/Adobe After Effects CS3/Plug-ins/DE_BuenaDepthCueMac/Rack Focus Helper.plugin/Contents/MacOS/Rack Focus Helper
225a9000 /Applications/Adobe After Effects CS3/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
225bc000 /Applications/Adobe After Effects CS3/Plug-ins/Format/CNImporter.plugin/Contents/MacOS/CNImporter
22634000 /Applications/Adobe After Effects CS3/Plug-ins/Format/LiveLink.plugin/Contents/MacOS/LiveLink
2268c000 /Applications/Adobe After Effects CS3/Plug-ins/Format/MediaIO/MediaIO2.plugin/Contents/MacOS/MediaIO2
226db000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/amefoundation.framework/Versions/A/amefoundation
2272e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/amesettingsui.framework/Versions/A/amesettingsui
22920000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ameproperties.framework/Versions/A/ameproperties
2297e000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/vci.framework/Versions/A/vci
2299f000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/vtranscoderengine.framework/Versions/A/vtranscoderengine
22ae4000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/vxmlpresetreader.framework/Versions/A/vxmlpresetreader
22b20000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/Xerces.framework/Versions/A/Xerces
23060000 /Applications/Adobe After Effects CS3/Plug-ins/Format/MP3.plugin/Contents/MacOS/MP3
230dd000 /Applications/Adobe After Effects CS3/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
23111000 /Applications/Adobe After Effects CS3/Plug-ins/Format/Premiere Import.plugin/Contents/MacOS/PremiereImport
23131000 /Applications/Adobe After Effects CS3/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Contents/MacOS/PremiereProImport
231e5000 /Applications/Adobe After Effects CS3/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
2323f000 /Applications/Adobe After Effects CS3/Plug-ins/Format/Vector Output.plugin/Contents/MacOS/Vic
233de000 /Applications/Adobe After Effects CS3/Plug-ins/Format/WAV.plugin/Contents/MacOS/WAV
233ef000 /Applications/Adobe After Effects CS3/Plug-ins/GridIron Nucleo/Nucleo.plugin/Contents/MacOS/NucleoPro
23635000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
23655000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
23662000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
23675000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
236ac000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
236c7000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
23f08000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
23f23000 /Applications/Adobe After Effects CS3/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
23f40000 /Applications/Adobe After Effects CS3/Plug-ins/ProAnimator 4.5.1 Mac/ProAnimator Importer 4.5.1/Contents/MacOS/ProAnimator Importer
2450c000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/BoxCreator.plugin/Contents/MacOS/BoxCreator
24580000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/BoxCreator_Lite.plugin/Contents/MacOS/BoxCreator_Lite
245f4000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/CubicDistribution.plugin/Contents/MacOS/CubicDistribution
24664000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/CubicDistribution_Lite.plugin/Contents/MacOS/CubicDistribution_Lite
246d4000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/CylinderCreator.plugin/Contents/MacOS/CylinderCreator
24748000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/CylinderCreator_Lite.plugin/Contents/MacOS/CylinderCreator_Lite
247bd000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/CylinderDistribution.plugin/Contents/MacOS/CylinderDistribution
2482e000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/LinearAssistant.plugin/Contents/MacOS/LinearAssistant
2489d000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/LinearAssistant_Lite.plugin/Contents/MacOS/LinearAssistant_Lite
2490c000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/MatrixCreator.plugin/Contents/MacOS/MatrixCreator
2497a000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/MatrixCreator_Lite.plugin/Contents/MacOS/MatrixCreator_Lite
249e8000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/PlanarAssistant.plugin/Contents/MacOS/PlanarAssistant
24a56000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/PyramidDistribution.plugin/Contents/MacOS/PyramidDistribution
24ac7000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/SpheroidCreator.plugin/Contents/MacOS/SpheroidCreator
24b3f000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/SpheroidCreator_Lite.plugin/Contents/MacOS/SpheroidCreator_Lite
24bb8000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Red Giant PlaneSpace/SpheroidDistribution.plugin/Contents/MacOS/SpheroidDistribution
24c92000 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
24cc2000 /Library/QuickTime/AJAVideoOutputClock.component/Contents/MacOS/AJAVideoOutputClock
24cd3000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Grid.plugin/Contents/MacOS/Grid
24d4c000 /Library/QuickTime/AJAVideoOutput.component/Contents/MacOS/AJAVideoOutput
24da2000 /Library/QuickTime/AJAMuxer.component/Contents/MacOS/AJAMuxer
24e5b000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/CycoreFX/Composite.plugin/Contents/MacOS/Composite
24e88000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Color_Key.plugin/Contents/MacOS/Color_Key
24ea5000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/CycoreFX/RadialBlur.plugin/Contents/MacOS/RadialBlur
24eaf000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/RoughenEdges.plugin/Contents/MacOS/RoughenEdges
24ed1000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/CycoreFX/ForceMB.plugin/Contents/MacOS/ForceMB
24f03000 /System/Library/Filesystems/URLMount/afp.URLMounter/Contents/MacOS/afp
24f77000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Echo.plugin/Contents/MacOS/Echo
24f7f000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Color_Balance_2.plugin/Contents/MacOS/Color_Balance_2
24f9c000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Basic_3D.plugin/Contents/MacOS/Basic_3D
2507f000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Stylize/S_EdgesInDirection.plugin/Contents/MacOS/S_EdgesInDirection
2509d000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Change_Color.plugin/Contents/MacOS/Change_Color
25174000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Photo Filter.plugin/Contents/MacOS/Photo_Filter
2517b000 /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
251cd000 /System/Library/Frameworks/AppleTalk.framework/Versions/A/AppleTalk
252ca000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Lens_Flare.plugin/Contents/MacOS/Lens_Flare
25308000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Tint.plugin/Contents/MacOS/Tint
25334000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Blur+Sharpen/S_Convolve.plugin/Contents/MacOS/S_Convolve
255f0000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Glow.plugin/Contents/MacOS/Glow
2560b000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/SmartBlur.plugin/Contents/MacOS/SmartBlur
25629000 /Applications/Adobe After Effects CS3/Plug-ins/AdvantEdge.plugin/Contents/MacOS/AdvantEdge
2566a000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Colorama.plugin/Contents/MacOS/Colorama
257f6000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Lighting/S_Glow.plugin/Contents/MacOS/S_Glow
25900000 /System/Library/QuickTime/QuickTime3GPP.component/Contents/MacOS/QuickTime3GPP
259f2000 /Library/QuickTime/FLV.component/Contents/MacOS/FLV
260cc000 /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS/QuickTimeStreaming
262f6000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Lighting/S_Glare.plugin/Contents/MacOS/S_Glare
26701000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Drop_Shadow.plugin/Contents/MacOS/Drop_Shadow
2670a000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Hue_Sat.plugin/Contents/MacOS/Hue_Sat
2671d000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/ColorsQuad.plugin/Contents/MacOS/ColorsQuad
26727000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/B-c-2.plugin/Contents/MacOS/B-c-2
26749000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/CycoreFX/LightSweep.plugin/Contents/MacOS/LightSweep
26753000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Curves.plugin/Contents/MacOS/Curves
26762000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Fast_Blur.plugin/Contents/MacOS/Fast_Blur
26774000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Lighting/S_LensFlare.plugin/Contents/MacOS/S_LensFlare
267c3000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Lighting/S_EdgeRays.plugin/Contents/MacOS/S_EdgeRays
27a72000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/adobe_personalization.framework/adobe_personalization
27d00000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/asneu.framework/asneu
27d2a000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/adobe_registration.framework/adobe_registration
27d43000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/AdobeUpdater.framework/AdobeUpdater
27eaf000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/AdobeLM_libFNP.dylib
2878b000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Fill.plugin/Contents/MacOS/Fill
28796000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Render/S_GradientRadial.plugin/Contents/MacOS/S_GradientRadial
287a5000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Rif.plugin/Contents/MacOS/RIF
287aa000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/ChangeToColor.plugin/Contents/MacOS/ChangeToColor
287c2000 /Applications/Digieffects/bin/libguide.dylib
28828000 /System/Library/Contextual Menu Items/AutomatorCMM.plugin/Contents/MacOS/AutomatorCMM
2885a000 /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
28890000 /Library/Frameworks/WkMacLibX.framework/Versions/A/WkMacLibX
28906000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/CycoreFX/PowerPin.plugin/Contents/MacOS/PowerPin
2919b000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/CycoreFX/ParticleWorld.plugin/Contents/MacOS/ParticleWorld
2c8cb000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/AutoContrast.plugin/Contents/MacOS/AutoContrast
2c919000 /Applications/GenArtsSapphireAE/config/sapphire-ae.bundle/Contents/MacOS/sapphire-ae
2d176000 /Applications/Adobe After Effects CS3/Plug-ins/ProAnimator 4.5.1 Mac/ProAnimator Plug-in 4.5.1/Contents/MacOS/ProAnimator Plug-in
2d6be000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Invert.plugin/Contents/MacOS/Invert
2d6c6000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/RadialShadow.plugin/Contents/MacOS/RadialShadow
2d6cc000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/FractalNoise.plugin/Contents/MacOS/FractalNoise
2d6eb000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Ramp.plugin/Contents/MacOS/Ramp
2d6f6000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Stylize/S_EmbossShiny.plugin/Contents/MacOS/S_EmbossShiny
2d714000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Lighting/S_DropShadow.plugin/Contents/MacOS/S_DropShadow
2d7c2000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Lighting/S_Rays.plugin/Contents/MacOS/S_Rays
2d7ec000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Levels2.plugin/Contents/MacOS/Levels2
2da2f000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Transform.plugin/Contents/MacOS/Transform
2da88000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Lighting/S_Glint.plugin/Contents/MacOS/S_Glint
2dafa000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Blend.plugin/Contents/MacOS/Blend
2dc2f000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Render/S_TextureChromaSpiral.plugin/Contents/MacOS/S_TextureChromaSpiral
2dcd2000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Luma_Key.plugin/Contents/MacOS/Luma_Key
2dcdc000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Gaussian_Blur.plugin/Contents/MacOS/Gaussian_Blur
2dced000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Color_HLS.plugin/Contents/MacOS/Color_HLS
2dcf4000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Unsharp_Mask.plugin/Contents/MacOS/Unsharp_Mask
2dcfb000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Render/S_Gradient.plugin/Contents/MacOS/S_Gradient
2dfbe000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/CannedWarp.plugin/Contents/MacOS/CannedWarp
2e04c000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Bevel_Alpha.plugin/Contents/MacOS/Bevel_Alpha
2e0b5000 /System/Library/Contextual Menu Items/FolderActionsMenu.plugin/Contents/MacOS/FolderActionsMenu
2f900000 /Applications/Adobe After Effects CS3/Plug-ins/Format/JPEG.plugin/Contents/MacOS/Jpg
2fac9000 /Library/Application Support/Adobe/Common/Plug-ins/CS3/MediaCore/Sapphire Plug-ins/Sapphire Blur+Sharpen/S_BlurMotion.plugin/Contents/MacOS/S_BlurMotion
3063f000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Find_Edges.plugin/Contents/MacOS/Find_Edges
306c6000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Wave_Warp.plugin/Contents/MacOS/Wave_Warp
306f9000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Radial_Blur.plugin/Contents/MacOS/Radial_Blur
307b5000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/AddGrain.plugin/Contents/MacOS/AddGrain
31483000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Numbers.plugin/Contents/MacOS/Numbers
3394b000 /Applications/Adobe After Effects CS3/Plug-ins/DE_BerserkV1_OSXUB/DE_BK_Newsprint_v1.plugin/Contents/MacOS/DE_Newsprint
33c87000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(AdobePSL)/multiprocessor support.plugin/Contents/MacOS/MultiProcessor Support
34a00000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(AdobePSL)/mmxcore.plugin/Contents/MacOS/MMXCore
34e28000 /Applications/Adobe After Effects CS3/Plug-ins/DE_AurorixV2_OSXUB/DE_AX_3DLighting_v2.plugin/Contents/MacOS/DE_3DLighting
3557e000 /Library/Frameworks/Tcl.framework/Versions/8.4/Tcl
36700000 /Library/Frameworks/UltimattePro.framework/Versions/A/UltimattePro
36b16000 /Applications/Adobe After Effects CS3/Plug-ins/Effects/Lens Blur.plugin/Contents/MacOS/Lens_Blur
371f7000 /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
37b17000 /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
38000000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Plug-ins/(MediaCore)/ImporterP2.bundle/Contents/MacOS/../Frameworks/libxalan-c.dylib
388ff000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/mcaacadec.framework/mcaacadec
3893c000 /Library/Frameworks/UltimatteTk.framework/Versions/8.4/UltimatteTk
399ae000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/mcmp4dmux.framework/mcmp4dmux
39e80000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/mch264dec.004.framework/mch264dec.004
3a0ab000 /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
3a25e000 /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
3a5a0000 /System/Library/Extensions/GeForce8xxxGLDriver.bundle/Contents/MacOS/GeForce8xxxGLDriver
3e000000 /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
40000000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
5cf7e000 /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
61977000 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
b0000000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/ahclient.framework/Versions/A/ahclient
ba900000 /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
bab00000 /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
c4000000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/mcmpegin.framework/Versions/1.4.0.21988/mcmpegin
cc000000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/MacOS/../Frameworks/mcmpgadec.framework/Versions/2.2.0.16471/mcmpgadec
f0000000 /Applications/Adobe After Effects CS3/Adobe After Effects CS3.app/Contents/Frameworks/mch264dec.framework/mch264decThread id: 1d72cba0
User stack:
26 start + 41 (in After Effects) [0x4029]
26 __start + 216 (in After Effects) [0x4102]
26 _main + 1411 (in After Effects) [0x4cc3]
26 __Z7EggMainbbbbbPcbl + 97 (in AfterFX) [0xc84d6b]
26 __ZN3egg7dvainit17DVAConsoleEnabledEv + 1947 (in AfterFX) [0xc84a0f]
26 __ZN13CAbstractText17ScrollToSelectionEv + 3664 (in AfterFX) [0xccfe1c]
26 __ZN13CAbstractText17ScrollToSelectionEv + 3804 (in AfterFX) [0xccfea8]
26 __ZN12CSwitchboard12ProcessEventEP11EventRecord + 486 (in AfterFX) [0xce904a]
26 __ZN12CSwitchboard10GetAnEventEP11EventRecord + 108 (in AfterFX) [0xce90e8]
26 _WaitNextEvent + 54 (in HIToolbox) [0x9573556d]
26 _WNEInternal + 151 (in HIToolbox) [0x9573560e]
26 _GetNextEventMatchingMask + 489 (in HIToolbox) [0x95735931]
26 _GetOrPeekEvent + 399 (in HIToolbox) [0x95735b28]
26 _ToolboxEventDispatcher + 86 (in HIToolbox) [0x956e2a6c]
26 _SendEventToEventTarget + 52 (in HIToolbox) [0x95675ecc]
26 __Z30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 405 (in HIToolbox) [0x9565957b]
26 __Z23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 2134 (in HIToolbox) [0x9565a4f6]
26 __Z29ToolboxEventDispatcherHandlerP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 1208 (in HIToolbox) [0x956880a8]
26 __Z23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1181 (in HIToolbox) [0x9565a13d]
26 __Z26StandardWindowEventHandlerP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 96 (in HIToolbox) [0x956de602]
26 __Z16HandleMouseEventP25OpaqueEventHandlerCallRefP14OpaqueEventRef + 791 (in HIToolbox) [0x95722bdb]
26 __Z17HandleWindowClickP15OpaqueWindowPtr5PointsmP14OpaqueEventRef + 505 (in HIToolbox) [0x95722de9]
26 __Z19HandleClickAsHIViewP15OpaqueWindowPtrP14OpaqueEventRef + 151 (in HIToolbox) [0x95723459]
26 __ZN6HIView5ClickEP14OpaqueEventRef + 329 (in HIToolbox) [0x957235f7]
26 __ZN5dvaui2ui7OS_View22CarbonEventHandlerProcEP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 512 (in dvaui) [0x88568d4]
26 __ZThn240_N7CEggApp19GetWorkspaceBuilderERKSbItSt11char_traitsItESaItEERN12dvaworkspace9workspace9WorkspaceE + 9976 (in AfterFX) [0x1257fbc]
26 __ZThn240_N7CEggApp19GetWorkspaceBuilderERKSbItSt11char_traitsItESaItEERN12dvaworkspace9workspace9WorkspaceE + 9610 (in AfterFX) [0x1257e4e]
26 __ZN5boost3_bi6bind_tIiPFiP25OpaqueEventHandlerCallRefP14OpaqueEventRefPvENS0_5list3INS0_5valueIS3_EENSA_IS5_EENSA_IS6_EEEEEclEv + 43 (in dvaui) [0x88ef5fb]
26 __ZN5dvaui2ui7OS_View26CallCarbonEventHandlerProcEP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 102 (in dvaui) [0x8858f52]
26 __ZN5dvaui2ui7OS_View16UI_HandleOSEventEPNS0_8OS_EventE + 29 (in dvaui) [0x885585b]
26 __ZN5dvaui2ui7OS_View16UI_DispatchEventEPNS0_8OS_EventE + 247 (in dvaui) [0x885a009]
26 __ZN5dvaui2ui7OS_View27UI_DispatchMouseEventFromOSEPNS0_8OS_EventE + 349 (in dvaui) [0x8855e6b]
26 __ZN5dvaui2ui7UI_Node21UI_DispatchMouseEventERKNS0_10MouseEventEb + 184 (in dvaui) [0x88618ac]
26 __ZN5dvaui2ui7UI_Node32UI_DispatchMouseEventTowardsLeafERKNS0_10MouseEventEb + 89 (in dvaui) [0x88617c3]
26 __ZN5dvaui2ui7UI_Node33UI_DispatchMouseEventTowardsLeafTINS1_18DispatchMouseEventEEESt4pairIbPS1_ERT_RKN7dvacore4geom6PointTIfEEb + 242 (in dvaui) [0x88f61aa]
26 __ZNK5dvaui2ui7UI_Node18DispatchMouseEventclEPS1_S3_RKN7dvacore4geom6PointTIfEE + 151 (in dvaui) [0x8861699]
26 __Z13EggAppVersionv + 6889 (in AfterFX) [0xd130f3]
26 __ZN5CView18DispatchMouseEventERKN2ae3egg10MouseEventE + 127 (in AfterFX) [0xceb6cd]
26 __ZN5CView18DispatchMouseEventERKN2ae3egg10MouseEventE + 348 (in AfterFX) [0xceb7aa]
26 __ZN11COutlineDir14GetOutlinePanoEv + 22106 (in AfterFX) [0xf573ec]
26 __Z14WF_WatchFolderPP9FILE_Spec + 142356 (in AfterFX) [0xf3f964]
26 __ZN11COutlineDir14GetOutlinePanoEv + 12511 (in AfterFX) [0xf54e71]
26 __ZN12CComposition16GetMarkerInfoStrERK6T_Time + 19566 (in AfterFX) [0xffda56]
26 __ZThn240_N7CEggApp19GetWorkspaceBuilderERKSbItSt11char_traitsItESaItEERN12dvaworkspace9workspace9WorkspaceE + 463864 (in AfterFX) [0x12c6cbc]
26 __Z11GetCEffectsP9BEE_Layer + 13594 (in AfterFX) [0xf47456]
26 __Z15FLT_HandleEventPK6T_TimePK14FLT_CameraViewP13PF_EventExtraP18FLT_ParamValueAtomPl + 266 (in FLT.dylib) [0x1604e0]
26 __Z24FLT_RegisterPseudoEffectPKcS0_RKSt6vectorI11PF_ParamDefSaIS2_EE + 106979 (in FLT.dylib) [0x1876bd]
26 __Z18FLTp_DoLazyGlobalsP10FLT_FCSpecPhS1_ + 6151 (in FLT.dylib) [0x16c601]
26 _main + 3022 (in ProAnimator Plug-in) [0x2d1824aa]
26 __Z15DoOptionsDialogP9PF_InDataP10PF_OutDataPP11PF_ParamDefP11PF_LayerDefP13PF_EventExtra + 2934 (in ProAnimator Plug-in) [0x2d18171e]
26 __ZN8InvigApp12DoMainWindowEv + 102 (in ProAnimator Plug-in) [0x2d3043a8]
26 __ZN10InvigAppAE16RunOptionsWindowEv + 1734 (in ProAnimator Plug-in) [0x2d306766]
26 __ZN18InvigOptionsWindow17ExitOptionsWindowEv + 143 (in ProAnimator Plug-in) [0x2d377c5f]
26 __ZN17InvigSceneManager19LoadSceneFromMemoryEPPcbib + 358 (in ProAnimator Plug-in) [0x2d253676]
26 __ZN9CommandIO14processCommandEv + 167 (in ProAnimator Plug-in) [0x2d1df04b]
26 __ZN14CommandEnabler14processCommandER9CommandIO + 471 (in ProAnimator Plug-in) [0x2d1deecb]
26 __ZN17InvigSceneManager8beginCmdER9CommandIOP14CommandEnabler + 197 (in ProAnimator Plug-in) [0x2d2476cb]
26 __Z12InvSceneReadR7AFileIOP6SceneX + 433 (in ProAnimator Plug-in) [0x2d1bd8a3]
26 _sprintf + 478 (in libSystem.B.dylib) [0x900b5c46]
26 ??? [0xffffffff]
26 __sigtramp + 43 (in libSystem.B.dylib) [0x900f92bb]
26 _U_LoadFrameworkBundle + 367 (in U.dylib) [0x7433e7]
26 _PlotIconRef + 0 (in HIServices) [0x942c10e4]
26 _exit + 33 (in libSystem.B.dylib) [0x900b5cb0]
26 ___cxa_finalize + 241 (in libSystem.B.dylib) [0x900b5dbc]
26 ___tcf_14 + 43 (in MediaLayer) [0x46c1d15]
26 __ZSt8_DestroyIPN3ASL12InterfaceRefIN2ML20IPluginModuleFactoryES3_EESaIS4_EEvT_S7_T0_ + 32 (in MediaLayer) [0x4960f44]
26 __ZN2ML21VSTAudioFilterFactory7ReleaseEv + 45 (in MediaLayer) [0x49cffad]
26 __ZN2ML21VSTAudioFilterFactoryD0Ev + 29 (in MediaLayer) [0x48bfde3]
26 ??? [0x4000004]
Kernel stack:
26 _user_trap + 945 [0x1ab4ba]
26 _exception_triage + 230 [0x12bad5]
23 _exception_deliver + 503 [0x12b798]
23 _mach_exception_raise + 179 [0x14a3d7]
20 _mach_msg_rpc_from_kernel + 302 [0x12db16]
20 _ipc_mqueue_receive + 750 [0x121292]
20 _thread_block + 33 [0x136f20]
15 _thread_block_reason + 135 [0x136e7c]
12 _thread_setrun + 3597 [0x136217]
12 _machine_idle + 271 [0x1ac3ec]
3 _ml_set_interrupts_enabled + 47 [0x1a4389]
4 _ml_set_interrupts_enabled + 47 [0x1a4389]
1 _thread_continue + 1180 [0x136cb3]
3 _mach_msg_rpc_from_kernel + 175 [0x12da97]
3 _ipc_kmsg_send + 278 [0x120530]
3 _ipc_mqueue_send + 469 [0x120f97]
1 _exception_deliver + 456 [0x12b769]
1 _mutex_unlock + 252 [0x19d5fc]
1 _mutex_lock + 68 [0x19d184]
1 _mutex_unlock + 252 [0x19d5fc]Thread id: 216d05d0
User stack:
26 _thread_start + 34 (in libSystem.B.dylib) [0x900be012]
26 __pthread_start + 321 (in libSystem.B.dylib) [0x900be155]
26 ___NSThread__main__ + 308 (in Foundation) [0x9455c9a4]
26 -[NSThread main] + 45 (in Foundation) [0x9455cdfd]
26 __Z10CallSystemPKc + 152780 (in AfterFX) [0x10bdd50]
26 __Z10CallSystemPKc + 118413 (in AfterFX) [0x10b5711]
26 __Z10CallSystemPKc + 154225 (in AfterFX) [0x10be2f5]
26 -[NSConditionLock lockWhenCondition:] + 69 (in Foundation) [0x945a2b35]
26 -[NSConditionLock lockWhenCondition:beforeDate:] + 144 (in Foundation) [0x945a2bd0]
26 -[NSCondition waitUntilDate:] + 236 (in Foundation) [0x945a2dbc]
26 _semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x9008d2e6]Thread id: 216d0208
User stack:
26 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x902f4057]
26 ??? [0x5be5d95]
26 ??? [0x5be6567]
26 _MPWaitOnQueue + 208 (in CarbonCore) [0x902f5afc]
26 _TSWaitOnConditionTimedRelative + 202 (in CarbonCore) [0x902d4cd2]
26 _TSWaitOnCondition + 126 (in CarbonCore) [0x902f5e7f]
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 216d2ba0
User stack:
26 ??? [0x5be5d95]
26 ??? [0x5be6567]
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 1e1ac3c8
User stack:
26 ??? [0x5be5d95]
26 ??? [0x5be6567]
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 216cfe40
User stack:
26 __Z11CMMConvTaskPv + 54 (in ColorSync) [0x91eb6d4e]
26 __Z20pthreadSemaphoreWaitP18t_pthreadSemaphore + 42 (in ColorSync) [0x91ea43f8]
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 216d1c80
User stack:
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 1da314f0
User stack:
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 1f35f3c8
User stack:
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 1cd2b5d0
User stack:
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 216cf2e8
User stack:
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 216cef20
User stack:
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 218e3410
User stack:
26 __ZN3ASL123_GLOBAL__N__Metaloaf_pro_ext_adobe_MediaCore_ASL_Foundation_Make_Mac_.._.._Src_Mac_MacAsyncFileReader.cpp_00000000_D12FC47F8TaskProcEPv + 69 (in ASLFoundation) [0x255e363]
26 ___semwait_signal + 10 (in libSystem.B.dylib) [0x9009446e]Thread id: 218e3048
User stack:
26 __ZN3ASL17ThreadedWorkQueue11PrivateImpl16InternalTaskProcEPv + 17 (in ASLFoundation) [0x2572081]
26 __ZN3ASL27ThreadedWorkQueueCommonImpl3RunEv + 117 (in ASLFoundation) [0x255b533]
26 __ZN3ASL17ThreadedWorkQueue11PrivateImpl14GetNextRequestElRPNS_7IOpaqueE + 90 (in ASLFoundation) [0x25584dc]
26 _TSWaitOnC -
Don Bitters iii
April 5, 2010 at 7:13 pmI apologize, that post was a lot longer than I thought it would be. I’ve emailed ed directly, so If a moderator wants to remove it, that’de be fine.
Don -
Edward Wu
April 6, 2010 at 6:44 pmHi Don,
Thanks for submitting the crash report. We’ll investigate into why you’re running into those issues.
Best,
Edward
