Activity Forums Zaxwerks ProAnimator color banding problem
  • ProAnimator color banding problem
    Posted by Dave Fleming on April 25, 2006 at 5:37 pm
    The continuing saga…I’ve imported the Illustrator file and I’m applying a camera preset to fly by the logo. I’m using an Object Style that employs a gradient in the color (for reflectivity, I assume). Why do all of the object styles that have a gradient also have annoying color banding problems as the gradient changes? I’m using the highest quality settings possible, but can’t smooth this out. Is it the texture map?
    Dave
    WPTZ
    Matt Rhodes replied 20 years, 4 months ago 2 Members · 1 Reply
  • Matt Rhodes
    April 25, 2006 at 8:27 pm
    Hi Dave.
    I would guess you’re seeing a limitation of the texture map applied as a reflection map.
    You may need a higher resolution map if you’re seeing undesired banding.
    If you’d like to post a picture to this forum, we’d be happy to voice an opinion.
    Alternately, you may send me a screenshot and I’ll take a look: matt@zaxwerks.com
    Thanks.
    Matt Rhodes
    Zaxwerks, Inc.
