Activity Forums Apple Final Cut Pro Legacy Pro res layoff issue
  • Pro res layoff issue
    Posted by Jahil Maplestone on November 21, 2007 at 5:08 pm
    I Have a 1080i 59.94 pro res HQ sequence and my easy setup to match. Approx TRT 1:30:00:00
    I’m laying off to Digi beta with a Kona 3 doing the down convert and cropping for a 4:3 pan and scan version.
    Everything is rendered and looks fine on all monitors.
    When I drag the sequence to the ETT window it pops up with a writing video box w/ meter saying it will take 4hrs.
    Surely this is not a normal part of a pro res work flow but i can’t seem to make it work any other way.
    Any clues?
    thanks
    Chris Borjis replied 18 years, 10 months ago 2 Members · 1 Reply
  • Chris Borjis
    November 21, 2007 at 7:06 pm
    Something is having to be rendered and is probably playing fine in realtime without rendering.
    When you ETT, the rendering MUST happen so you don’t have any problems during layback.
    I would consider this normal. Just let it do its thing.
