Activity › Forums › Apple Final Cut Pro Legacy › Pro Res 422 HQ Question?
  • Pro Res 422 HQ Question?
    Posted by Jonny Cates on August 10, 2012 at 4:20 pm
    I mistakenly checked the HQ position while sizing several formats into 1280 x 720 Pro Res 422.
    When layering these formats on the timeline, it seems the HQ is causing some playback problems – like a slow motion jerky effect. I do have Unlimited RT selected too.
    But if I select lower playback rates, they will then play OK. But of course the Dynamic resolution is gone.
    “Can I re-transcode these same Pro Res HQ files – but this time without the HQ?”
    Or do I have to go back to the original files to redo? Is this because of the HQ was selected, or is there something else going on?
    Thanks….
    Jonny Cates
    Jonny Cates replied 14 years, 1 month ago 2 Members · 2 Replies
  • Jerry Wise
    August 10, 2012 at 5:32 pm
    What is your Sequence Setting.?
  • Jonny Cates
    August 10, 2012 at 6:25 pm
    Jerry; settings are….
    Frame size: 1280 x 720 HDTV 720p (16:9)
    Pixel: Square
    Filed Dominance: None
    Timebase: 30
    Compressor: ProRes 422 (HQ)
    100%
    Audio:
    48kHz
    16-bit
    Channel Grouped
    Jonny Cates
