Activity Forums Zaxwerks Pro Animator FX – Animating a Cylinder Wrap
  • Pro Animator FX – Animating a Cylinder Wrap
    Posted by Patrick Briar on October 3, 2013 at 2:19 pm
    I am trying to animate 3D text around a 3D primitive sphere. I set the text in the first pose with the “Cylinder Wrap” distribution. The Checkbox “animate around cylinder center” is checked. I set the second pose to animate 360 degrees around the common center. When I play the animation back, it does not animate at all.
    Am I missing something?
    Thank you,
    Patrick.
    Edward Wu replied 12 years, 11 months ago 2 Members · 1 Reply
  • Edward Wu
    October 4, 2013 at 8:03 pm
    Hi Patrick,
    The best way to animate a rotation is using the “Spin Y” action. This control is located in the Pose Actions section. Once you select Spin Y, type in 360 for the rotation, then check the Use Common Center checkbox and the text should spin for you.
    Best,
    Edward
